Box Sync running script
I need a script to check that Box Sync is running in the background. I have tried adding a few as extension attributes but they don't seem to work. I just need a report to see if the process is actually running or not.
Any ideas?
Best answer by chriscollins
@Brianmarum
As a start, this works fine as an extension attribute:
box_status=$(ps aux | grep "Box Sync Monitor" | grep -v "grep")
if [ ! -z "$box_status" ]; then
    echo "<result>Running</result>"
    echo "<result>Not Running</result>"
mark_mahabir
  • October 26, 2016
@Brianmarum
  • October 27, 2016
This worked perfectly. Thanks a million!
