Can Not Correctly Add AirPrint Printers to macOS via Jamf Pro - Please Help
  • Sep 17, 2024 4:34 PM UTC
  • 4 replies
  • 298 views
Is there no way to correctly add AirPrint printers with Jamf Pro?  I see that it's exceedingly easy with Jamf School, which we don't have (despite being a school.)  It's also exceedingly easy with iOS devices. But for some reason it appears to be impossible for macOS via Jamf Pro.
I keep revisiting this over the years, and there's never been any updates.
I'm paranoid because LPD is being deprecated and will disappear at some point soon, even though it's been years since the ominous warning showed up.
I know that adding it via Terminal technically works, but it always has a generic printer icon.  I don't want it to technically work.  I would like the printers to have the correct icons associated with the printer name as a visual cue for the students.
Am I missing something?  Or is this still not fully implemented for Jam Pro for the past who-knows-how-many-years?
  • Sep 17, 2024 7:25 PM UTC
It's been awhile since I had to add printers via jamf, but I was able to get the correct drivers and printer icons via the following method with jamf pro:
-Create a proper install package for the drivers; whether that be through custom built driver packages with composer or a pre built download package with jamf. Remember to capture both the driver binaries and the PPD files; if necessary. Upload the package to jamf cloud.
-Define the printers on one local machine. After the printers are configured, enable the cups interface, browse to 127.0.0.1:631, use the CUPS interface to obtain the cups device uri and the correct path to the PPD.
-Use the information obtained from cups to define the printer with jamf. pro
-Finally build a policy that first installs the driver and ppd and then maps the printer using the definition you built earlier. The jam printer manager may make this easier, I haven't played with it yet. https://github.com/jamf/jamf-printer-manager
that said the above process works every time and is not that bad after you get used to it. Thank god for the cups web interface. hope that helps.
kwoodard
  • Sep 18, 2024 4:56 AM UTC
I am still upset that Jamf removed Jamf Admin. Wasn't a perfect app, but it worked well. Was very good with printers. Printers captured and added to Jamf Pro worked nearly every time. Now, I can add a printer via the website multiple times (each time the same exact way) and usually one will work... I just have to keep trying and one will eventually work. I just saw the new Print Manager...I hope to try it out tomorrow.
  • Oct 10, 2024 4:06 PM UTC
Gave it a try, but it does the same thing.  It saves you the time on filling it out in Jamf, but the printer is not installed correctly when added via Jamf.  Has the same generic inkjet icon.
  • Oct 10, 2024 4:09 PM UTC
It works fine if I use LPD.  It does not work if added via AirPrint, regardless if I manually copy the driver.  That's the issue I'm having.  Something about Jamf Pro is not doing it correctly.
I tried Jamf Printer Manager, and it does the same thing.  It just saves you the time of having to fill it out, but the end result is a printer with a generic inkjet icon.
