Casper imaging from 10.10.3 problem
Forum|alt.badge.img+20
My configuration consists of a OS X. Yosemite.dmg
Is anyone getting the OS X.dmg installing as a package instead of Block Copy ??
when i run casper imaging on a mac using 10.9.5 i get Block Copy installation on the targeted computer, so this is working fine.
whats up with 10.10.3 all of a sudden ?
JSS 9.51
Best answer by cdev
There's a known bug that affects Casper in versions prior to 9.63 (if I remember correctly) to solve for this exact issue. Upgrading to 9.65 or 9.72 will resolve it.
scottb
  • June 17, 2015
I think you need at least Casper Suite 9.6 to get it working with 10.10...
cdev
  • June 18, 2015
  • June 18, 2015
@cdev is correct, you need to be running 9.65 or 9.72. I had the same problem when I was running version 9.61 of the JSS. As a workaround, you could simply use Casper Imaging 9.72 for imaging and upgrade your JSS when the time is right.
  • June 18, 2015
ok, thanks. until my company upgrades I will try a newer version of Casper imaging
