Casper NetInstall based off 10.7 modular image... not netbooting
Hey all,
I'm troubleshooting a Casper 8.21 NetInstall set created with 10.7. The image wasn't booting over the network, so poking around inside I see that there is no i386 folder holding the booter files.
I noticed in the pdf for the NetInstall creator tool (version 3.2) that it only mentions 10.6. Can anyone comment if this version is compatible with creating a 10.7 NetInstall set?
Thoughts?
Douglas Worley Apple Certified System Administrator Apple Certified Trainer AppleCare Certified Service Trainer Certified Casper Administrator
bentoms
Forum|alt.badge.img+35
  • 4331 replies
  • August 22, 2011
There is a new 10.7 tool for this in the resource kit.
Regards,
Ben.
  • 238 replies
  • January 19, 2012
Oh really? Where might this be, because I am also seeing the issue that daworley reports (no i386 folder, no booter file, etc.).
Thanks,
--Andy
  • 238 replies
  • January 19, 2012
never mind, I found it. Apparently on 10.7 we are supposed to use the Casper NetBoot Automator Action instead of the Netinstall Creator tool. Good to know :)
  • 238 replies
  • January 20, 2012
OK, so I was able to create a netboot image using the SIU and Casper automator action, using my InstaDMG base image. However, the image does not auto login as root or start the imaging app. I tried creating the .AppleSetupDone file, and this just drops me into the login panel. Any suggestions for how to make my image auto-login & launch the imaging app? I thought that the automator action would do this for me, but I guess I was expecting too much...
  • 20 replies
  • January 21, 2012
@andyindy unfortunately it did not do this for me either so when I created my netboot image i made sure to boot into the OS and enable root and set casper imaging to run at login.
Cookie policy
Cookie settings
