Cisco Secure Client VPN 5.1.1 & 5.1.2 - System Certificate Trust Settings Popup DUO Issue
  • February 8, 2024
  • 160 views
Hello all,
I am running into an issue trying to deploy Cisco Secure Client v 5.1.0.136 & 5.1.2 where the bundled Duo desktop is causing a pop up to appear. Anytime the installer is pushed a security system cert trust setting pop up will appear. If you click cancel, the VPN installs as it should and there are no issues. I am trying to push these as silent installs so end users don't have to interact with anything, but I can't seem to find a way to do so. We are not DUO customers and just want to use the Secure Client VPN.
I have been following this thread in my troubleshooting, so I am aware it is Duo desktop causing the issue. I have tried the steps in that thread regarding pushing out a Duo cert, but the pop up still keeps appearing. I have reached out to both Cisco and DUO about it, however neither have been very helpful. Cisco basically said DUO Desktop isn't supposed to be there even though it is and DUO wouldn't help since I wasn't a customer. I'm curious if anyone out there has been able to deploy Secure Client VPN without having DUO desktop at all or if they've been able to circumvent that pop up from appearing. We can't be the only ones who use Secure Client VPN and aren't DUO customers. Any help is greatly appreciated!
Best answer by McAwesome
If you are using the choices.xml route, you can prevent installation of DUO entirely.
https://hcsonline.com/images/PDFs/Deploying_Cisco_AnyConnect.pdf
  • February 8, 2024
