Configuring GlobalProtect for iOS - how to guide?
  • Apr 19, 2022 11:00 PM UTC
  • 4 replies
  • 319 views
Hello everyone,
Has anyone had any luck setting up Global Project for iOS ?
After an exhaustive search of PA Networks support documentation I have been unable to locate any documentation that is specific to installing and configuring Global Protect for iOS using Jamf. MDM software.  The only relevant documentation that PA Networks provides is specific to Airwatch and inTune , however there is nothing specific to Jamf and I'm beginning to think that perhaps Jamf is not supported based on PA Networks MDM support page, included as a reference.
https://docs.paloaltonetworks.com/globalprotect/9-1/globalprotect-admin/mobile-endpoint-management/set-up-a-mobile-endpoint-management-system/manage-the-globalprotect-app-using-a-third-party-mdm/always-on-vpn-configurations/configure-an-always-on-vpn-configuration-using-airwatch/configure-an-always-on-vpn-configuration-for-ios-endpoints-using-airwatch
  • Apr 20, 2022 10:53 AM UTC
  • Apr 20, 2022 8:37 PM UTC
Thanks for the support doc rossmclaren, very useful... Have you had any luck yourself rolling GP for iOS out, and if so do you have any additional information that you can share that reviews the steps needed
  • Apr 21, 2022 9:57 AM UTC
@Colonel_Clank
We have it configured for use via Endpoint Manager [Intune] so the experience isn't 100% like for like, but once you've got the AppConfig keys configured and pushed out, you should be good to go!
Configure the GlobalProtect App for iOS
Is there a new link for this?
