Cortex XDR requires system extension authorization
  • June 16, 2020
  • 26 replies
  • 388 views
Show first post
  • October 19, 2021
Thank you!
For anyone who it may help, I tried this with perfect results:  Went to Smart Groups, and set
Profile Name > has >  Cortex XDR Agent Unified Configuration Profile
Then I scope my Cortex installation policy to that Smart Group.  This forces the Cortex XDR app not to install until the profile is installed first.
Has worked perfectly for me so far!
P.S I also experimented and found that if I uploaded the signed profiles that are provided in the PaloAlto document @davidhiggs referenced above, I can actually install the Cortex XDR agent first, and then install the profiles after, and it still appears to work perfectly! I am at first prompted to "install a system extension", but that prompt goes away as soon as the profiles install and the system is rebooted. The agent reports as expected to Cortex endpoint management administration.  This was on an M1 test device running 11.6.
Jeanette
