Darshan Hiranandani : How can I troubleshoot and fix issues with starting FileVault on my Mac?
  • Jul 1, 2024 5:40 AM UTC
  • 98 views
Hello,
I'm experiencing difficulties enabling FileVault on some macOS devices that were auto-enrolled via JAMF Connect. Despite having the policy in place, FileVault encryption did not initiate.
I've opened a ticket for new devices, but there are still a few lingering devices where FileVault remains disabled. When attempting to manually enable FileVault and cycle the key
Thank you for your help.
Best regards,
Darshan Hiranandani
1 reply
AJPinto
  • Jul 1, 2024 11:37 AM UTC
Rule 1: Do not enable FileVault with Jamf Connect.
Rule 2: Use a Configuration Profile to enable FileVault from Jamf Pro or whatever MDM you use.
How to troubleshoot FileVault enablement.
Make sure you are enabling FileVault with a configuration profile, do not put the configuration profile in the prestage as there is a product issue with Jamf and doing that causing problems. Assuming the FileVault Configuration Profile is configured correctly.
If for some reason FileVault does not enable, do the following.
  • Exempt the device from the Configuration Profile enabling FileVault.
  • Reboot the device
  • Retarget the device with the Configuration Profile.
  • Reboot the device again
  • Monitor if the user is prompted to enable FileVault.
If the above does not work, enable FileVault manually using System Settings or the fdesetup command.
  • The fdesetup command will usually tell you whyFileVault is failing to enable if it cannot enable FileVault.
  • Ensure the user has a Secure Token.
All and all managing FileVault is pretty simple if you enable it the way Apple tells you to which is with a Configuration Profile.
