Declarative Device Management: Not Enabled
  • Apr 15, 2024 7:25 AM UTC
  • 4 replies
  • 240 views
mallej
I have two Macs that have Declarative Device Management: Not enabled and I think they should actually have it enabled.
They are on macOS 14.2.1 and 14.3.1 and are enrolled in Jamf 11.4.1
Is there anything I can check or force them to have DDM enabled?
mvu
  • Apr 16, 2024 4:12 PM UTC
Have these 2 Macs checked in recently? Maybe try updating to 14.4.1 and running sudo jamf manage to see if the Declarative Profiles come down from Jamf.
mallej
  • Apr 21, 2024 9:38 PM UTC
Hi Obi,
thanks, but that did not helped.
  • Apr 29, 2024 4:51 AM UTC
How is everything going now, have you found something useful?
mallej
  • May 2, 2024 12:43 PM UTC
No, sorry.
I have observed that the same devices behave differently on different Jamf servers that I have tested. On one Jamf server they are DDM enabled, on another they are not. I have not found a way to retroactively enable DDM on a device that is not DDM enabled. A software update does not help, nor does a new enrollment.
