Declarative Device Management not enabled
  • Dec 11, 2024 8:13 PM UTC
  • 8 replies
  • 311 views
abacpits
Hey Folks,
we have recently moved with our entire Fleet of iOS and macOS Devices to Jamf Pro.
today Apple released iOS18.2 and we wanted to Update our iOS Devices using DDM. We noticed that non of our Devices, macOS or iOS, has DDM enabled.
Does anyone know why?
thanks!
Shyamsundar
  • Dec 12, 2024 5:57 AM UTC
Is your JAMF hosted as onPrem or is it hosted as JAMF Cloud, DDM is available only on JAMF Cloud
Jamf Pro automatically enables declarative device management on devices that meet the following requirements:
  • Computers with macOS 13 or later
  • Devices with iOS 16 or iPadOS 16 or later
abacpits
  • Dec 12, 2024 10:10 AM UTC
We are on Jamf Cloud and all requirements are fulfilled (OS Version etc.). All Macs, iPads and iPhones are not DDM enabled.
mvu
  • Dec 12, 2024 12:44 PM UTC
Where do you see that it is not enabled?
In the Software Updates tab, is the "Use new feature" on? Have you tried sending out a DDM Scheduled update command to some test devices yet?
abacpits
  • Dec 12, 2024 12:48 PM UTC
yes, we tried that and it is not enabled and the command failed. In every Single device it says "Declarative Device Management not enabled", even our Macs. very Strange
mvu
  • Dec 12, 2024 1:57 PM UTC
That is strange. Paper says that Jamf Pro enables automatically. Might be worth a support ticket.
Let us know what you find.
https://learn.jamf.com/en-US/bundle/jamf-pro-documentation-current/page/Declarative_Device_Management.html
abacpits
  • Dec 12, 2024 2:11 PM UTC
Ticket is open, I'll let you know what the solution was
Any feedback from the ticket? I am also encountering the same. We meet all requirements, but DDM is not being enabled on devices.
abacpits
  • May 12, 2025 7:17 AM UTC
Yes, you have to contact Jamf Support and they have to reset something in your environment. It took about 2-3 weeks, but in the end they solved it. It is nothing you can fix on your own.
