Delving into Vision Pro management with JAMF Pro
  • Jan 9, 2025 6:12 PM UTC
  • 213 views
MMTechno
Hi everyone, just exploring this and i just need to confirm a few things , if anyone knows that would be a massive help. I will get my hands on a device soon but i need to hit the ground running.
  1. So for vision OS 2 we do not need managed apple IDs anymore and it will work fine without for a prestage enrollment?
  2. Will i be able to hide bits and pieces from the set-up assistant? Lets say i don't want users to login to their personal apple IDs. The Prestage does not make any mentions of visionOS
  3. Can this be set-up as a shared device or is it not supported for VisionPro?
  4. Will enrollment customisation work ?
  5. Will i need any custom configuration profiles or will they just work from : Mobile Devices -> Configuration Profiles. I cant see what applies to visionOS only.
  6. Do i need Jamf Trust and Jamf Security cloud to keep these devices secure? I mean what is the best practice in terms of AV/EDR?
Those who have implemented it, what has your experience been?
Thanks
Shyamsundar
  • Jan 10, 2025 4:08 AM UTC
We have enrolled an AVP with JAMF, below are our observations
1.) Yes, With Vision OS 2 supporting Zero-touch enrollment, Devices can be added to ABM and can be synced to JAMF via DEP.
2. Vision Pro is considered a Mobile device it's similar to how you Manage your iOS devices. you don't need any specific config for Vision Pro in JAMF. you can hide the Setup-assistant
3. Vision Pro can't be configured as Shared Devices currently.
4.) Yes, it will work
5.) You don't have separate profiles for Vision Pro, as it's considered a Mobile device you can create a Configuration Profile same as how you created one for managing iOS
refer to the below link for Management capabilities for Vision Pro
https://learn.jamf.com/en-US/bundle/technical-articles/page/Vision_Pro_Management_with_Jamf_Pro.html
6.) Yes you can use Jamf Trust and Security Cloud.
Please let me know if you need any other information
MMTechno
  • Jan 10, 2025 7:52 AM UTC
Thank you for this, So in terms of securing the device is Jamf Trust the only option?
MMTechno
  • Jan 11, 2025 11:30 AM UTC
Will i need a managed apple id at all to complete the onboarding? Or is it irrelevant
