Deploy wireless settings to MacBooks
Sorry if this has been answered before but I couldn't find anything specific on this. When dealing with the iPads you can set the wireless settings in Configuration Profiles, but I cannot find how to do the same thing with our Laptops.
Andrew
Best answer by mcooper
To enable the use of OS X Configuration Profiles in the JSS you need to go into Settings > Computer Management > Security, and check "Enable push notifications."
easyedc
  • June 16, 2015
Same way. Configuration profile. Network Payload and I set them as Computer Level payload.
  • June 16, 2015
When I click on the Configuration profile under the Computers tab I cannot add anything to it, the button to add is not there. I checked with my co-worker who has full rights to JSS and he doesn't have the Add button either.
  • June 16, 2015
  • June 16, 2015
That's exactly what I needed. It's working now. Thanks!
  • June 16, 2015
I was able to create a config profile for wireless settings but when I went to scope it would only show 13 macs. All 13 macs it shows are mac mini's, no macbook air's. We have a lot more than 13 macs in our environment.
bpavlov
  • June 16, 2015
Are you using Sites? That would determine what computers you see in the scope.
  • June 16, 2015
We do but if I go to scope in another section such as Policies I see over 160 macs.
  • June 16, 2015
Are all your Macs showing up as MDM Capable? If this is something you only just enabled today, its possible some of them haven't gotten the settings to show up as MDM manageable devices.
  • June 16, 2015
Yup it looks like they are slowly trickling in, I'm up to 20 now. Thanks!
