Deploying a default Wallpaper using script is prompting users to "allow"
  • Mar 19, 2026 12:11 PM UTC
  • 6 replies
  • 275 views
FerrisBNA
Hello all,
   I am working on deploying the updated company wallpaper.  Current attempt is using the script below, but it gives the user a that “Jamf wants access to control Finder...” (screenshot attached). Maybe there is a better way to do this.
currentUser=$(/bin/ls -l /dev/console | /usr/bin/awk '{print $3}')
sudo -u "$currentUser" -H osascript -e 'tell application "Finder" to set desktop picture to POSIX file "/Library/DesktopWallpaper/backgroundDefault.jpg"'
MusicCityMac
Forum|alt.badge.img+19
  • Mar 19, 2026 1:06 PM UTC
Take a look at this guide from Jamf on deploying wallpaper to a computer.
dmccluskey
  • Mar 19, 2026 1:45 PM UTC
You need to use a apple script this will avoid any prompts.
This is an example of the one I use.
# $3 is the logged in user - default for most policies.
sudo -u $3 /usr/bin/osascript <<ENDofOSAscript
tell Application "Finder"
set the desktop picture to {"Library:corp:wallpaper:General.jpg"} as alias
end tell
ENDofOSAscript
  • Mar 19, 2026 2:10 PM UTC
Give Desktoppr a try. I use this to set a default background on our staff users with the option to change it. It works quite well with a launch agent.
https://github.com/scriptingosx/desktoppr
FerrisBNA
  • Mar 19, 2026 7:52 PM UTC
end tell
ENDofOSAscript
For this script, wouldn’t the logged-in user need to be an administrator?
-Pat
mfletch
  • Mar 20, 2026 4:59 PM UTC
I use desktoppr and it works great.
  • Mar 25, 2026 4:20 PM UTC
That prompt is macOS TCC for Apple Events (Jamf/osascript trying to automate Finder). If you want to avoid user prompts entirely, I’ve had the best luck using desktoppr (no Finder automation) or Jamf’s wallpaper payload.
If you do stick with AppleScript, you’ll need to pre-approve the automation via a PPPC profile (AppleEvents) so Jamf/osascript is allowed to control Finder.
Reference (walkthrough + what to whitelist): Apple Privacy Preferences (PPPC) Policy
