Difference between "disown" and "unmanage"?
  • Dec 6, 2023 1:02 PM UTC
  • 177 views
The Jamf profiles on our devices (iPads) are set to "non-user-removable". Some of our students get to keep their iPads after they left our school and of course they want to have unmanaged devices without any restrictions and profiles.
Is it enough to disown the devices in Jamf, move them to the trash and tell the users to "erase all content and settings"?
Or is it neccessary to unmanage the devices first?
Or in other words: does disown entail unmanage?
sayr01
  • Dec 6, 2023 3:43 PM UTC
Hi,  we have similar scenario.  we tend to remove from apple school manger first and the send remote wipe command.  we then just delete the entry from JAMF.  We make sure that activation lock in unticked when we wipe.
AJPinto
  • Dec 6, 2023 9:35 PM UTC
I would suggest wiping any device you relinquish ownership of, and not relying on the user to do this. MDM can release a device from ASM/ABM, but verify this is being done. If the device is also being released from ASM you are good. If the device is not being released, you also need to do that if you are giving the devie away.
