Dockutil Script
Hi all,
I'm new to JAMF and I'm creating my first image from scratch.
I'm wanting to use dockutil to customise the dock at login.
I've placed dockutil in /usr/local/bin/ and I've compiled the following script from others I've seen online:
LoggedInUser=$3
LoggedInUserHome="/Users/$3"
configureDefaultDock() {
echo "Logged in user is $LoggedInUser" echo "Logged in user's home $LoggedInUserHome"
if [ -e /usr/local/bin/dockutil ] ; then dockutilVersion=/usr/local/bin/dockutil --version echo "dockutil version: $dockutilVersion"
echo "Clearing Dock..." /usr/local/bin/dockutil --remove all --no-restart $LoggedInUserHome
echo "Adding Launchpad..." /usr/local/bin/dockutil --add '/Applications/Launchpad.app' --no-restart $LoggedInUserHome
echo "Adding Calendar..." /usr/local/bin/dockutil --add '/Applications/Calendar.app' --no-restart $LoggedInUserHome
echo "Adding Notes..." /usr/local/bin/dockutil --add '/Applications/TextEdit.app' --no-restart $LoggedInUserHome
echo "Adding App Store..." /usr/local/bin/dockutil --add '/Applications/App Store.app' --no-restart $LoggedInUserHome
echo "Adding Google Chrome..." /usr/local/bin/dockutil --add '/Applications/Google Chrome.app' --no-restart $LoggedInUserHome
echo "Adding Slack..." /usr/local/bin/dockutil --add '/Applications/GarageBand.app' --no-restart $LoggedInUserHome
echo "Adding Downloads..." /usr/local/bin/dockutil --add '~/Downloads' --no-restart $LoggedInUserHome
echo "Adding Downloads..." /usr/local/bin/dockutil --add '~/Applications' --no-restart $LoggedInUserHome
touch $LoggedInUserHome/Library/Preferences/com.company.docksetup.plist
else echo "dockutil not installed, skipping initial dock setup..." fi
killall -KILL Dock
I've created a login policy to run the script, and it runs, but I get the following:
"Executing Policy dockutilA05
Running script dockutilA05.sh...
Script exit code: 2
/Library/Application Support/JAMF/tmp/dockutilA05.sh: line 33: syntax error: unexpected end of file
Error running script: return code was 2."
I'm sure this is simple, so instead of butchering it I thought I'd ask.
Best answer by McKinnonTech
Thanks a lot @franton and @edgardeveij!
I've made those changes and it works a treat.
Here's the script I ended up with:
LoggedInUser=$(python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "
LoggedInUserHome="/Users/$LoggedInUser"
if [ -e /usr/local/bin/dockutil ];
then
   dockutilVersion=`/usr/local/bin/dockutil --version --version`; echo "dockutil version: $dockutilVersion"
echo "Clearing Dock..."; /usr/local/bin/dockutil --remove all --no-restart "$LoggedInUserHome"
echo "Adding Calendar..."; /usr/local/bin/dockutil --add '/Applications/Calendar.app' --no-restart  --position 1 "$LoggedInUserHome"
echo "Adding TextEdit..."; /usr/local/bin/dockutil --add '/Applications/TextEdit.app' --no-restart --position 2 "$LoggedInUserHome"
echo "Adding Google Chrome..."; /usr/local/bin/dockutil --add '/Applications/Google Chrome.app' --no-restart --position 3 "$LoggedInUserHome"
echo "Adding GarageBand..."; /usr/local/bin/dockutil --add '/Applications/GarageBand.app' --no-restart --position 4 "$LoggedInUserHome"
echo "Adding GarageBand..."; /usr/local/bin/dockutil --add '/Applications/Sibelius 7.5.app' --no-restart --position 5 "$LoggedInUserHome"
echo "Adding Applications..."; /usr/local/bin/dockutil --add '~/Applications' --no-restart --position 6 "$LoggedInUserHome"
echo "Adding Downloads..."; /usr/local/bin/dockutil --add '~/Downloads' --no-restart --position 7 "$LoggedInUserHome"
killall -KILL Dock
To get past dockfixup/SIP I also had to I boot into recovery, disabled SIP in the Terminal, run something like this:
 /usr/libexec/PlistBuddy -c "delete:add-app" /System/Library/CoreServices/Dock.app/Contents/Resources/com.apple.dockfixup.plist
/usr/libexec/PlistBuddy -c "delete:add-doc" /System/Library/CoreServices/Dock.app/Contents/Resources/com.apple.dockfixup.plist
Enable SIP and reboot.
Some more info on SIP here:
https://jamfnation.jamfsoftware.com/discussion.html?id=17276
  • September 6, 2016
Decided I'd butcher it, and I ended up with this:
LoggedInUser=$3
"if"  -e /usr/local/bin/dockutil "then" dockutilVersion=/usr/local/bin/dockutil --version
echo "Clearing Dock..." /usr/local/bin/dockutil --remove all --no-restart "$LoggedInUserHome"
echo "Adding Launchpad..." /usr/local/bin/dockutil --add '/Applications/Launchpad.app' --no-restart --position 1 "$LoggedInUserHome"
echo "Adding Calendar..." /usr/local/bin/dockutil --add '/Applications/Calendar.app' --no-restart  --position 2 "$LoggedInUserHome"
echo "Adding TextEdit..." /usr/local/bin/dockutil --add '/Applications/TextEdit.app' --no-restart --position 3 "$LoggedInUserHome"
echo "Adding App Store..." /usr/local/bin/dockutil --add '/Applications/App Store.app' --no-restart --position 4 "$LoggedInUserHome"
echo "Adding Google Chrome..." /usr/local/bin/dockutil --add '/Applications/Google Chrome.app' --no-restart --position 5 "$LoggedInUserHome"
echo "Adding GarageBand..." /usr/local/bin/dockutil --add '/Applications/GarageBand.app' --no-restart --position 6 "$LoggedInUserHome"
echo "Adding Applications..." /usr/local/bin/dockutil --add '$HOME/Applications' --no-restart --position 7 "$LoggedInUserHome"
echo "Adding Downloads..." /usr/local/bin/dockutil --add '$HOME/Downloads' --no-restart --position 8 "$LoggedInUserHome"
touch "$LoggedInUserHome"/Library/Preferences/com.company.docksetup.plist
"else" echo "dockutil not installed, skipping initial dock setup..." "fi"
killall -KILL Dock
With this result:
Executing Policy dockutilA05 Running script dockutilA05... Script exit code: 0 Script result: Logged in user is localadmin Logged in user's home /Users/localadmin /Library/Application Support/JAMF/tmp/dockutilA05: line 11: if: command not found dockutil version: Clearing Dock... /usr/local/bin/dockutil --remove all --no-restart /Users/localadmin Adding Launchpad... /usr/local/bin/dockutil --add /Applications/Launchpad.app --no-restart --position 1 /Users/localadmin Adding Calendar... /usr/local/bin/dockutil --add /Applications/Calendar.app --no-restart --position 2 /Users/localadmin Adding TextEdit... /usr/local/bin/dockutil --add /Applications/TextEdit.app --no-restart --position 3 /Users/localadmin Adding App Store... /usr/local/bin/dockutil --add /Applications/App Store.app --no-restart --position 4 /Users/localadmin Adding Google Chrome... /usr/local/bin/dockutil --add /Applications/Google Chrome.app --no-restart --position 5 /Users/localadmin Adding GarageBand... /usr/local/bin/dockutil --add /Applications/GarageBand.app --no-restart --position 6 /Users/localadmin Adding Applications... /usr/local/bin/dockutil --add $HOME/Applications --no-restart --position 7 /Users/localadmin Adding Downloads... /usr/local/bin/dockutil --add $HOME/Downloads --no-restart --position 8 /Users/localadmin /Library/Application Support/JAMF/tmp/dockutilA05: line 27: else: command not found
franton
  • September 6, 2016
Yep, don't rely on "$3". You should try something like this instead.
LoggedInUser=`python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "
  • September 6, 2016
@franton I'll try using that in the morning, thank you.
  • September 6, 2016
Gave that a try @franton, same thing:
Executing Policy dockutilA05 Running script dockutilA05... Script exit code: 0 Script result: Logged in user is localadmin Logged in user's home /Users/localadmin /Library/Application Support/JAMF/tmp/dockutilA05: line 11: if: command not found dockutil version: Clearing Dock... /usr/local/bin/dockutil --remove all --no-restart /Users/localadmin Adding Launchpad... /usr/local/bin/dockutil --add /Applications/Launchpad.app --no-restart --position 1 /Users/localadmin Adding Calendar... /usr/local/bin/dockutil --add /Applications/Calendar.app --no-restart --position 2 /Users/localadmin Adding TextEdit... /usr/local/bin/dockutil --add /Applications/TextEdit.app --no-restart --position 3 /Users/localadmin Adding App Store... /usr/local/bin/dockutil --add /Applications/App Store.app --no-restart --position 4 /Users/localadmin Adding Google Chrome... /usr/local/bin/dockutil --add /Applications/Google Chrome.app --no-restart --position 5 /Users/localadmin Adding GarageBand... /usr/local/bin/dockutil --add /Applications/GarageBand.app --no-restart --position 6 /Users/localadmin Adding Applications... /usr/local/bin/dockutil --add ~/Applications --no-restart --position 7 /Users/localadmin Adding Downloads... /usr/local/bin/dockutil --add ~/Downloads --no-restart --position 8 /Users/localadmin /Library/Application Support/JAMF/tmp/dockutilA05: line 27: else: command not found
  • September 6, 2016
Just gave the following a go:
Ended up with:
franton
  • September 7, 2016
Your bash if construction needs work. You currently have:
dock stuff here
You should think of it more like:
then
   dock stuff here
The amalgamation of lines can cause issues as the error now looks like it's trying to execute a command on the local path, that simply isn't there.
Also:
won't work. It's missing backticks
dockutilVersion=`/usr/local/bin/dockutil --version`
and the lines like:
are missing semicolons between the echo and dockutil commands:
echo "Adding Launchpad..."; /usr/local/bin/dockutil --add '/Applications/Launchpad.app' --no-restart --position 1 "$LoggedInUserHome"
edit:
reviewing my post: somehow backticks disappeared in message.
  • September 7, 2016
then
killall -KILL Dock
  • September 8, 2016
Great script @McKinnonTech
I "borrowed" it today for a lab. Using outset I did not have to disable SIP
L
jmahlman
  • September 8, 2016
My version which was built on a basic script from @colin.
This one adds icons based on our dummy receipt (cohort). It also doesn't mess with the dockfixup.plist, it just clears the dock.
https://github.com/jmahlman/uarts-scripts/blob/master/dockMaster.sh
# Original created By: Colin Bohn, Stanwood-Camano School District (cbohn@scsd.ac)
# Customized by John Mahlman, University of the Arts Philadelphia
# Last Updated July 19, 2016
# Name: DockMaster
# Purpose: Set the contents of the dock on login based on computer type (cohort)
# and what applications are available on the local machine.
sleep 5 # we need to wait for the dock to actually start
#### Where's our JAMF binary?
jamfbinary=$(/usr/bin/which jamf)
##### Lets make sure we have DockUtil
if [ ! -f "/usr/local/bin/dockutil" ]; then
    echo "Installing DockUtil from JSS"
    "$jamfbinary" policy -event dockutil
        echo "Unable to install DockUtil, aborting!"
        exit 1
du="/usr/local/bin/dockutil"
##### Find out who we are modifying
if [ ! -n "$3" ]; then
    user=$3
    user=$(python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "
echo "Running DockMaster on $user"
##### Let's find that cohort...
if [ -f /Library/JAMF DM/Cohort/*.txt ]; then
    cohort=$(cat /Library/JAMF DM/Cohort/*.txt)
    echo "Cohort set to $cohort"
    echo "No cohort available! Adding default icons cohort"
    cohort="NONE"
#### Bundled Apps Checker Functions
officeIcons ()
    wordversion=$(defaults read "/Applications/Microsoft Word.app/Contents/Info.plist" CFBundleShortVersionString)
    # Checking for Office 2016
    sleep 2
    if [[ $wordversion == "15."* ]]; then
        echo "Adding Office 2016 apps"
        $du --add "/Applications/Microsoft Word.app" --no-restart /Users/$user
        $du --add "/Applications/Microsoft Excel.app" --no-restart /Users/$user
        $du --add "/Applications/Microsoft Outlook.app" --no-restart /Users/$user
        $du --add "/Applications/Microsoft Powerpoint.app" --no-restart /Users/$user
        # Checking for Office 2011
        if [ -d "/Applications/Microsoft Office 2011/" ]; then
            echo "Adding Office 2011 apps"
            $du --add "/Applications/Microsoft Office 2011/Microsoft Word.app" --no-restart /Users/$user
            $du --add "/Applications/Microsoft Office 2011/Microsoft Excel.app" --no-restart /Users/$user
            $du --add "/Applications/Microsoft Office 2011/Microsoft Outlook.app" --no-restart /Users/$user
            $du --add "/Applications/Microsoft Office 2011/Microsoft Powerpoint.app" --no-restart /Users/$user
iWorkIcons ()
    echo "Adding installed iWork Apps"
    if [ -e "/Applications/Pages.app" ]; then
        $du --add "/Applications/Pages.app" --no-restart /Users/$user
    if [ -e "/Applications/Numbers.app" ]; then
        $du --add "/Applications/Numbers.app" --no-restart /Users/$user
    if [ -e "/Applications/Keynote.app" ]; then
        $du --add "/Applications/Keynote.app" --no-restart /Users/$user
#### Get a clean slate going here
echo "Removing all items from the dock"
$du --remove all --no-restart /Users/$user
sleep 2 # we need to give this time to work or we'll get errors with "replacing" items instead of adding them.
#### Items for all/no cohorts
echo "Adding browsers"
$du --add "/Applications/Safari.app" --no-restart /Users/$user
if [ -e "/Applications/Google Chrome.app/" ]; then
    $du --add "/Applications/Google Chrome.app" --no-restart /Users/$user
# We have two different firefox types, lets figure out which one is installed
if [ -e /Applications/Firefox* ]; then
    firefox=$(find /Applications -type d -maxdepth 1 -name Firefox*)
    $du --add "$firefox" --no-restart /Users/$user
# Add Office icons to all cohorts
officeIcons
# Every user gets a downloads folder too
echo "Adding the Downloads folder"
$du --add "~/Downloads" --view fan --display stack --sort dateadded --no-restart /Users/$user
#### Add dock items for FACSTAFF cohort
if [ $cohort == "FACSTAFF" ]; then
    echo "Adding apps for FACSTAFF"
    $du --add "/Applications/Calendar.app" --no-restart /Users/$user
    $du --add "/Applications/Preview.app" --no-restart /Users/$user
    $du --add "/Applications/iTunes.app" --no-restart /Users/$user
    $du --add "/Applications/Photo Booth.app" --no-restart /Users/$user
    $du --add "/Applications/Time Machine.app" --no-restart /Users/$user
    if [ -e "/Library/KeyAccess/KeyCheckout.app/" ]; then
        $du --add "/Library/KeyAccess/KeyCheckout.app" --no-restart /Users/$user
    if [ -e "/Applications/Network Connect.app/" ]; then
        $du --add "/Applications/Network Connect.app" --no-restart /Users/$user
    $du --add "/Applications/Self Service.app" --no-restart /Users/$user
    $du --add "/Applications/App Store.app" --no-restart /Users/$user
    $du --add "/Applications/System Preferences.app" --position end --no-restart /Users/$user
    # This should be the end of the applications in the dock, anything after should be a folder
    $du --add "/Applications" --view grid --display folder --sort name --no-restart /Users/$user
    $du --add "~/Documents" --view fan --display stack --sort dateadded --no-restart /Users/$user
#### Add dock items for OFFICE cohort
elif [ $cohort == "OFFICE" ]; then
    echo "Adding apps for OFFICE cohort"
    $du --add "/Applications/Launchpad.app" --position beginning --no-restart /Users/$user
    $du --add "/Applications/Contacts.app" --no-restart /Users/$user
    $du --add "/Applications/Notes.app" --no-restart /Users/$user
    $du --add "/Applications/Messages.app" --no-restart /Users/$user
#### Add dock items for PUBLIC cohorts
#### This one has a lot of different cohorts,
#### You can break it down as much as you want
elif [ $cohort == "LAB" ] || [ $cohort == "STUDIO" ] || [ $cohort == "SUITE" ] || [ $cohort == "SMART-CLASSROOM" ]; then
    echo "Adding apps for $cohort cohort"
    iWorkIcons
    $du --add "/Applications/Image Capture.app" --no-restart /Users/$user
#### Add dock items for CHECKOUT cohort
elif [ $cohort == "CHECKOUT" ]; then
    echo "Adding apps for CHECKOUT cohort"
#### Add dock items for KIOSK cohort
elif [ $cohort == "KIOSK" ]; then
    echo "Adding apps for KIOSK cohort"
fi #end of cohorts
# Restart the dock after everything is done
sleep 5
killall Dock
