Does pushing the same payload from multiple config profiles cause a problem?
  • Oct 20, 2020 1:36 PM UTC
  • 6 replies
  • 220 views
Basically the title, does pushing the same config profile with different settings applied cause conflicts?
Here is a very specific example:
Security and Privacy
One profile has the firewall turned on and another has the firewall off (not checked).
Basically, which wins? Do they fight? We had some weird behavior happen when pushing the same payload multiple times with different settings.
Any advise or guidance is appreciated.
Best answer by rjashton
They definitely clash and it is a bit random which one 'wins' so to speak. The unofficial Apple response about this MDM 'feature' about which one wins is usually 🤷🏻‍♂️
I think that in certain Mobile Device profiles Jamf Pro now allows you to pick which parts of a payload actually get deployed (I think the Restrictions payload) and I would anticipate more of this sort of thing in the future. Where this isn't available you could potentially create a custom profile that includes only the payloads you need in it... but this has potential to be a bit fiddly and error prone!
Best practice is usually to have only one of each payload scoped to a device. If you had a set of devices that don't need your default security settings I'd probably create a group for excluding these from your defaults. Then I'd reuse that group to scope my desired settings for those devices.
  • Oct 20, 2020 1:48 PM UTC
Tangentism
  • Oct 20, 2020 2:01 PM UTC
As @rjashton says, there will be a clash but my experience has shown that, especially with CP's with 'Restrictions' payload, the most restrictive will win. I had two CP's with the same settings but one had Touch ID disabled and it won out.
Best way to discover the effect is scope both to a test device and see if the firewall is on or off
  • Oct 20, 2020 3:19 PM UTC
Thanks for the responses! It seems the best solution to make sure you don't have multiple payloads of the same type competing, and consolidate as much as reasonable.
ega
  • Sep 23, 2021 3:01 PM UTC
Also when using Profile Creator on macOS you will see in the General payload 2 settings that make the profile unique
1- Payload Identifier
A reverse-DNS style identifier (com.example.myprofile, for example) that identifies the profile. This string is used to determine whether a new profile should replace an existing one or should be added.
and
2 - Identifier
A globally unique identifier for the profile.
Both of these need to be Globally Unique.
What I do is use the unix command line tool uuidgen to create a unique identifier and add to the end of the Payload Identifier like:
com.example.myprofile.F168DDBD-67FF-4CCA-ACCE-72A9315CEXXX
And then change the Identifier to the the same unique id like:
This way I can use the exact same profile in whatever Site I want and Jamf and macOS see them as different profiles buy they set the same keys.
Also if you forget to change one of these Jamf will give a "Can't make object from file" error when the upload is attempted.
I hope this helps save someone time.
  • Feb 27, 2025 6:44 PM UTC
I'd appreciate input on my scenario.  I have a 'Base Config' profile that every computer gets on enrollment.  It contains an org.mozilla.firefox.plist payload with a default setup (bookmarks, extensions, etc.). Some sales counter computers act as dumb terminals so the browser cache/history needs to be cleared on quit.  For everyone else this doesn't have to be the case.
For reference, the relevant section is below.
<key>SanitizeOnShutdown</key>
<dict>
<key>Cache</key>
<true/>
<key>Cookies</key>
<true/>
<key>Downloads</key>
<true/>
<key>FormData</key>
<true/>
<key>History</key>
<true/>
<key>Locked</key>
<true/>
<key>OfflineApps</key>
<true/>
<key>Sessions</key>
<true/>
<key>SiteSettings</key>
<false/>
</dict>
I could create a separate 'Sales Counter' profile for them to inherit that's basically a duplicate of the 'Base Config' with some minor changes, but I'm wondering if there's a simpler way.
Let's say both profiles have a firefox plist payload but the `Base Config` does not include the `SanitizeOnShutdown` key and the `Sales Counter` profile payload only has the `SanitizeOnShutdown` key.  Would that work?  I could make the `Preference Domain` unique for each, but would Firefox still apply the config?
Thanks for the input in advance!
  • Feb 27, 2025 7:50 PM UTC
<dict>
<key>Cache</key>
<true/>
<key>Cookies</key>
<true/>
<true/>
<key>FormData</key>
<true/>
<key>History</key>
<true/>
<key>Locked</key>
<true/>
<true/>
<key>Sessions</key>
<true/>
<false/>
</dict>
There are many solutions to the problem but personally I would take the Firefox configuration out of the ‘base config’ and have it in its own profile. You have the ‘base config’ Firefox profile scoped to all computers but exclude the sales counter devices. I would then deploy the specific Firefox config to the sales counter devices.
