EA scripting query
Is an EA script able to output multiple lines of output? For instance, we want to display two attributes out of a plist file at /Users/loggedInUser/Library/Preferences/com.dms.echo.plist
The plist file looks like this...
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>NSNavPanelExpandedSizeForOpenMode</key> <string>{712, 448}</string> <key>NSStatusItem Preferred Position Item-0</key> <real>881</real> <key>echoDays</key> <integer>30</integer> <key>echoing</key> <true/> <key>dmsEchoHasBeenLaunched</key> <true/> <key>supportLogging</key> <true/> </dict> </plist>
We really only want the "echoDays" and "echoing" attributes displayed. Can a script format the output so those two attributes appear one line over the other?
Best answer by rderewianko
Okay, i took a stab at this
The first two are single result EA's the third combines them
loggedInUser=$(python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "
Echoing=$(defaults read /Users/$loggedInUser/Library/Preferences/com.dms.echo.plist echoing)
#if that result is blank then
    if [ -z "$Echoing" ]; then
    echo "<result>No Echoing</result>"
#if its not blank print the result
    echo "<result>$Echoing</result>"
echoDays=$(defaults read /Users/$loggedInUser/Library/Preferences/com.dms.echo.plist echoDays)
    if [ -z "$echoDays" ]; then
    echo "<result>No echoDays</result>"
    echo "<result>$echoDays</result>"
    echoing_Result="no Echoing"
    echoing_Result=$Echoing
    echoDays_Result="no echoDays"
    echoDays_Result=$echoDays
echo "<result> $echoing_Result & $echoDays_Result </result>"
  • 486 replies
  • November 8, 2018
boberito
Forum|alt.badge.img+22
  • 451 replies
  • November 8, 2018
Use printf it won't print a new line like echo.
So you could do
printf "<result>" then printf whatever you want, multiple values, multiple printfs. Then printf "</result>"
But the above solution works too.
  • 45 replies
  • November 9, 2018
Works great. Thanks guys!
  • 7882 replies
  • November 9, 2018
I typically drop any items into a bash array in the script, and then use printf to print the array, splitting on line breaks.
if [ -e "/Users/$loggedInUser/Library/Preferences/com.dms.echo.plist" ]; then
     echoDaysVal=$(defaults read /Users/$loggedInUser/Library/Preferences/com.dms.echo.plist echoDays)
     echoingVal=$(defaults read /Users/$loggedInUser/Desktop/com.dms.echo.plist echoing)
     results=("echoDays: ${echoDaysVal}" "echoing: ${echoingVal}")
     echo "<result>$(printf '%s
' "${results[@]}")</result>"
     echo "<result>No results</result>"
That will or should show 2 lines for the results. What you need to keep in mind is that not all areas of the Jamf UI are able to show multiple lines for EAs or other items, so your results here may vary. in some places it may show up as one line, not two. Jamf also has an odd track record of enabling, then breaking this functionality. Some versions may not display multiple lines and others might.
  • 486 replies
  • November 11, 2018
I've never used arrays but now you've got me interested @mm2270
Cookie policy
Cookie settings
