EAP-TLS Certificate based WiFi authentication
  • February 8, 2018
  • 28 replies
  • 1452 views
Hello
I'm really struggling to get our Macs authenticating to our Wireless Network using Certificate based authentication. I've followed a few help guides but none of them seem to work, has anyone managed to get this working.
Below is a copy of our Configuration profile
Best answer by sbirdsley
I had to open an Apple Enterprise support ticket after having setup issues as well as we needed the cert to pull down as the machine name for various systems that check for that
Had to update username entry to:
host/%ComputerName%.%AD_DomainNameDNS%
Not sure if that will help you at all
  • February 8, 2018
For my environment the key was getting the computer certificate to show up in the System Keychain, and then setting the machine name (with $ symbol at the end) for the username (e.g. computername$)
  • February 9, 2018
What sort of certificate are you using, Computer or User? Are you domain joined?
We have the same setup with but with User certificates.
No bind, Enterprise Connect logged in for Kerberos.
Same profile setup as above but Distribution Method is Self Service and Level User.
User logs into Self Service to install the profile, that calls to the CA using the Kerberos auth and pulls down the cert.
Finally what's the error when you try and push?
Cheers
Al
ThijsX
Forum|alt.badge.img+20
  • Employee
  • February 9, 2018
Did you create a cert template on your CA?
Edit: in our situation we dont need the username to be $COMPUTERNAME$.
Try selecting TLS and PEAP and no username.
Also include your ROOTCA certificate within the tree.
  • February 9, 2018
Currently the Macs are requesting the user to choose from two certificates. One is the AD Certificate that has been generated, the other is a jamfcloud cert.
  • February 9, 2018
We cloned the standard user one in the CA and used that... just make sure you set the options correctly as ours initially caused issues with S/MIME on iOS - turn signing off and no need to publish to AD....
I'm sure when I was testing i tried Mac as the cert template name and for some reason it wasn't working... we reverted to **_WiFi_Certificate
Not sure if this made any difference but it works!
  • February 9, 2018
Tried leaving the username blank and I'm still seeing the same pop up window asking which certificate to use.
@al_platt when you had Mac as the template name, were you seeing the same pop up?
It's frustrating as once you select the correct cert, it does connect but we'd like everything to be automated. I did read the pop up could be due to the CA Root cert not including a subject name but I've checked and the subject is populated with the CA FQDN.
Edit - Sorry, I should have said, this is machine based authentication and not user!
ThijsX
  • Employee
  • February 9, 2018
Are there still credentials (username/pw) store in the keychain referred to your Wi-Fi network?
  • February 9, 2018
Only for our current corporate network which is different to our EAP-TLS test network.
I've removed our other corporate network from a client machine to test but still the same.
  • February 9, 2018
When i tried Mac as the template name the profile just wouldn't install.. cert installation failed - as i say, weird and not sure if related.
What if you issue a cert manually via the CA web portal and then try manually connecting with that?
  • February 9, 2018
We followed a few steps documented here: http://sachinparmarblog.com/wireless-802-1x-eap-tls-on-mac-os-x/
  • February 9, 2018
Just noticed i have authentication set to WPA/WPA2 Enterprise NOT just WPA2 Enterprise.
  • February 9, 2018
  • February 9, 2018
@sbirdsley I think that's cracked it!!
No prompts and connects straight away.
Thanks so much!
  • February 9, 2018
@jthurwood Awesome!
  • February 12, 2018
@sbirdsley Are you using Apple Profile manager to create the profile?
We are trying to get WIRED 802.1x authentication to work a system (machine) level.
From what I've seen in JAMF nation discussions, one can't create a machine based wired authentication profiles with the JSS.
Any input would be much appreciated
  • February 12, 2018
@AHolmdahl I am using JAMF Pros to setup and deploy the configuration profiles
We have been able to get direct system level .1x authentication working in our environment using the "username" details I provided previously in this post and an AD certificate payload with the appropriate server setup
The only issue I have found in our environment/setup is depending on what you have the Network interface setting configured to has caused some issues when the system is used in a "dock" setup with the network interface connected through another means. It appears if you set the Network Interface to say use "First Active Ethernet" we have found this will only work if the system is directly connected to Ethernet or through a direct adapter (MBP > Thunderbolt to Ethernet Adapter) and see .1x failures with network connection made to Dell USB docking stations, split through IP Phone, connected Thunderbolt Displays, etc.
This appears to be resolved in our environment at least with 10.13 and changing the interface setting in the configuration profile to "Any Ethernet"
m3ir
  • January 3, 2019
@sbirdsley is the host/%ComputerName%.%AD_DomainNameDNS% entry will work on user level to disappear the certificates choose window and auto connect?
Thanks
  • January 22, 2019
@sbirdsley I am also interested in a WIRED only configuration profile using EAP-TLS with NO username, just the system certificates. Do you have any experience with this?
  • March 13, 2019
Having the same issue with our ADCS Connector... looking for machine based Certs from ADCS for our EAP-TLS wifi.. I can generate an ADCS certificate and it gets delivered by JAMF Pro to the Machine but then I am forced to choose the certificate to use instead of automatically joining with Machine Cert the first time. I get presented with the com.apple.kerberos.kdc and the Machine ADCS generated certificate. If I select the Machine certificate it gets on and remembers from then on but not sure why it is not using the machine cert in the first place. Any ideas Peeps?
  • March 13, 2019
@sbirdsley
How do you update the below setting in a Mac?
  • March 14, 2019
@sbirdsley Having the same issue with our ADCS Connector... looking for machine based Certs from ADCS for our EAP-TLS wifi.. I can generate an ADCS certificate and it gets delivered by JAMF Pro to the Machine but then I am forced to choose the certificate to use instead of automatically joining with Machine Cert the first time. I get presented with the com.apple.kerberos.kdc and the Machine ADCS generated certificate. If I select the Machine certificate it gets on and remembers from then on but not sure why it is not using the machine cert in the first place
@cjatsbm We're not currently using the Jamf ADCS Connector (but looking to implement it in the near future). Just checking if you are already combining all of the payloads in the same profile (e.g. network, root and issuing certificates, AD certificate)? I ran into the same issue you described when we first set up our 802.1X EAP-TLS profile where it wouldn't auto-authenticate using the ADCS machine certificate and combining all of the payloads in the same profile worked for me. Good luck!
  • April 12, 2019
@cjatsbm When you install a device-level profile, the cert goes in to the System keychain. Only connection attempts made the the system will use that connection (com.apple.network.eap.SYSTEM.identity.wlan.ssid.$yourssid). These connection attempts are typically after wake/boot/login. If the user manually selects $yourssid from the menu, it's looking for a com.apple.network.eap.USER.identity.wlan.ssid.$yourssid, if it doesn't have one, it will prompt for the cert then create that identity in the login keychain.
This doesn't explain why it's not connecting automatically after the profile is installed, but should explain the prompt.
One workaround for all this is to also install user-level network profile. All the settings can be the same.
  • April 12, 2019
Has anyone had any issues with the configuration profile applying before a name change of the device. so the cert in system keychain will show Macbook-Pro.domain instead of the serial.domain and then binding would break after the name change?
  • May 1, 2019
@dustink yeah that's just a timing thing, if are you wanting to use the serial number of the device
I use two policies to handle this, probably better ways, but it works for me.
I create a AD bind policy with the Active Directory Payload, let's call it: Active Directory Binding, let's create a custom trigger for it say 'adbind'
I then create a second policy that runs a script that changes the name of the machine to it's serial number and then calls the Active Directory Binding policy. below is a small portion of a larger script but this is essentially what I use.
serial_number=`ioreg -l | grep IOPlatformSerialNumber|awk '{print $4}' | cut -d " -f 2`
/usr/sbin/scutil --set ComputerName $serial_number
/usr/sbin/scutil --set LocalHostName $serial_number
/usr/sbin/scutil --set HostName $serial_number
sleep 10s
echo "Active Directory Binding"
${jamfbinary} policy -event "adbind"
