'Enbale Lost Mode' not enabled for iOS devices
  • Dec 27, 2023 12:49 PM UTC
  • 5 replies
  • 130 views
Hello,
I want to enable 'Lost Mode' for a lost device.
I cannot find this option in 'Management Tab' for the concerned device.
This option is also missed for other iOS devices.
Any idea how to troubleshoot that?
Thanks
  • Dec 27, 2023 1:58 PM UTC
First thought: Check to make sure the devices are supervised as well as managed (Inventory > General). If they're not supervised, Lost Mode (as well as many other options) won't show up under Management.
  • Dec 27, 2023 2:49 PM UTC
@mdp
Thanks for the prompt response. I h've double checked, the concerned device is supervised/managed/DEP !
  • Dec 27, 2023 3:14 PM UTC
Hmm. My only other thought: It looks like you're on Jamf 10, based on the roundness of the Lost Mode icon you posted. Can you give the exact version you're on? (On Jamf 11 it's on the Dashboard, can't remember right now if that's true for 10 as well.) I recall about a year ago there being some talk about an issue with Lost Mode and certain versions of Jamf, particularly with shared iPads. I might update your Jamf instance at least to the end of 10, if it's not already.
  • Dec 27, 2023 3:17 PM UTC
Here's what I was thinking about: https://community.jamf.com/t5/jamf-pro/enable-lost-mode-missing-in-management-tab-ios-16-2-only/td-p/280116
Looks like it was resolved in Jamf 10.43.0.
  • Dec 27, 2023 3:26 PM UTC
Jamf VERSION
10.50.0-
