Extend idle timeout - 15 minutes is not long enough
  • Feb 28, 2024 8:13 PM UTC
  • 6 replies
  • 163 views
Here everyone - please go and vote for this in the feature requests.  It is annoying to have to spend 1/2 the day logging back into Jamf and waiting for the page to load.
https://ideas.jamf.com/ideas/JN-I-27272
jamf-42
  • Feb 28, 2024 8:36 PM UTC
This option is part of jamf premium.. I’m not sure but the shared code base of standard jamf cloud may make this not an option
back in the days of on prem you just tickled a file..
there are some fudges / plugins that may help.. but eventually you learn to live with it …
  • Feb 28, 2024 10:04 PM UTC
Checkout my little project to help with this https://github.com/fveja/JSSCaffeinate in the mean time.
jamf-42
  • Feb 29, 2024 3:32 PM UTC
EDIT: only just noticed this was for JAMF School.. my comment may not be correct..
@Fveja this seems to work well with Arc Browser and a boost.. no need for 3rd party extensions
  • Feb 29, 2024 3:56 PM UTC
Have not tried it on JAMF School, as I don't have access.  I created that and tested it on JAMF Pro, but would love to know if it works on JAMF School as well.
scottb
  • Feb 29, 2024 10:08 PM UTC
There is also the issue of the Jamf web interface logging you out if you reload the page.  Not 100% of the time, but most of the time and I hate it!
I was told to "only have one page open" when using Jamf which is absurd...
scottb
  • Feb 29, 2024 10:14 PM UTC
Also, if you want to keep a page alive (frontmost page) you can use this in Script Editor, which I do.
Just make a new file and paste this in.  Hit the > "Run" button to use it.
tell application "Safari" repeat set URL of document of window 1 to URL of document of window 1 delay 999 --551 seconds end repeat end tell
