FileVault 2 Individual Key Validation smart group not accurate ??
Forum|alt.badge.img+20
I have file vault 2 computer configuration going on computers. User logs out and gets prompted to enter password for file vault 2 to turn on et....
I have a smart group with the criteria: FileVault 2 Individual Key Validation is 'valid'
the only computer that shows up in this group is a single computer running 10.9
the computers running 10.10 do not show up in this smart group.
has anyone else encountered this ?
Best answer by chriscollins
@tcandela The first thing you are going to need to do is update your JSS. 9.6 was the first version compatible with Yosemite/10.10 and even in that initial release I remember some issues with Yosemite and FileVault reporting.
Update your JSS then report back if it resolved things.
  • July 9, 2015
Nope, I am on 9.63 and my 10.10 systems with keys marked as Valid are showing up with that same Smart Group criteria.
  • July 9, 2015
So far I have 6 computers that have file vault 2 turned ON via this computer configuration profile. The recovery key for each is in the JSS, and have encrypted 100% complete, but the only computer showing up in the smart group is a single 10.9
Running 9.51
  • July 10, 2015
  • July 10, 2015
yep, its definitely 9.51 causing this. I'll submit anther request to have the JSS updated.
afterwards i'll report back.
