Fix Autorisation for Beyond Trust
  • Sep 10, 2026 2:25 PM UTC
  • 7 replies
  • 177 views
LaurentCh
I have an issue with Beyond Trust Bomgar client on Macs Managed with my Jamf Pro instance.
I’ve made a Configuration Profile to allow Bomgar in the privacy settings, my test Mac got the rule but when i want to remote connect to my test Mac, i have to autorise 3 options.
I saw many topic about this, but even if i made the same rule, it’s not working.
If anyone has an idea? Thank you
MusicCityMac
Forum|alt.badge.img+19
  • Sep 10, 2026 3:12 PM UTC
Check out this post from last year that might be helpful
LaurentCh
  • Sep 10, 2026 4:02 PM UTC
Thank you ​@MusicCityMac for your suggestion, but i don’t have problems with the installs, but once the agent il installed ont managed Mac, and if i want to remote connect to a computer, user have to allow all the 3 options in the security and privacy settings.
I don’t understand why the Configuration Profile doesn’t work
MusicCityMac
  • Sep 10, 2026 6:15 PM UTC
​@LaurentCh, I misunderstood what you were asking. My apoligies.
Apple has decided for the sake of privacy and security that the end user has to enable those three options, there is no way to do it via configuration profile or other remote option.
LaurentCh
  • Sep 15, 2026 12:11 PM UTC
I’m so sad to hear that, its very anoying, i’m goint to look for an other solution
mvu
  • Sep 15, 2026 1:26 PM UTC
We use BeyondTrust here as well. It is something the customer has to run through, but it is a 1-time thing. So, they step through it once, you won’t see it again on that client.
  • Sep 15, 2026 1:58 PM UTC
Try changing your identifier to com.bomgar.bomgar-scc.
MusicCityMac
  • Sep 15, 2026 2:14 PM UTC
Any solution that requires those security and privacy settings will run into those same limitations, there is no way around it.
