Flushing out dscl on logout for lab machine
I know this is an odd question, but I hope someone out in the JNation can assist. I am trying to setup a lab station build. On this build people login against our LDAP to a locked down profile. When they logout the profile is deleted.
The hiccup I am having is that our LDAP doesn't have a UniqueID to map to. I was hoping to map every user who logs in to #601 or something. What I need to know is how to I flush that record during logout so the next user can login using the same UniqueID? I assume I have to run some sort of dscl command before I delete the home folder.
Any help would be greatly appreciated!!!
Best answer by nessts
OK then why not set LDAP up properly and have a unique UID field per user. Or is that completely out of the question? Or why use LDAP at all and just put a local account on the computer, and have the home directory get erased every logout then the next person that logs in gets a fresh home. Sorry if I missed this above as I have tried to read and understand the problem. I do not see the benefit of using an LDAP solution if it is not setup properly and if nothing on the machine ever needs saved what is the benefit of using different login names?
  • June 4, 2015
Are you just asking how you would remove the user account in directory services that matches the UID you've specified for the locked down account?
Or do you mean something else?
  • June 4, 2015
I want to flush all records of the logged in user. Currently if I map UniqueID to #601 the first person can log in. The next logs in gets an error saying it cannot create a home folder. I imagine it is because there is a record on the computer for the first user with the same uniqueid
  • June 4, 2015
I tried adding a dscl . Delete /Users/$user to the logout script. I have user=$1 which is working for the rm /Users/$user.
  • June 4, 2015
dscl . delete /Users/$user + rm'ing the home directory should actually do what you want since that should purge the directory services record for that account and delete the home folder. I'm not certain if something gets left behind that is causing the Mac to not allow the next account to log in though.
  • June 5, 2015
@mm2270 That is what I have scripted now. dscl . delete /Users/$user
rm -rf /Users/$user
It is not working. It is deleting the home folder, but next user cannot log in with the same UniqueID. This is in 10.10, there must be some sort of cache that is stuck around that needs to be deleted as well.
  • June 5, 2015
not sure if it helps too much but I need to do the same sort of thing deleting any users who have not logged in for 24 hours - you might be able to adjust this script :
!/bin/sh
userList=dscl . list /Users UniqueID | awk '$2 > 1000 {print $1}'
echo "Deleting account and home directory for the following users..."
for a in $userList ; do find /Users -type d -maxdepth 1 -mindepth 1 -not -name "." -mtime +1 | grep "$a" if [[ $? == 0 ]]; then echo $a fi
done
it takes any user of UID above 1000 (generally non admin users) and deletes them at the mtime 1 being 1 day. So if you change +1 to 0 and set this as a log out script it might just work AND keep the admin accounts for you
  • June 5, 2015
I wonder if restarting DirectoryService would help?
killall DirectoryService
Not sure, but maybe it needs to be restarted in order for it to release that UID for the next login.
BTW, how exactly are you mapping that each LDAP user that logs in to the same UID? I've never seen that done before, so was curious how you were going about that? Or, was this all experimental at the moment and you aren't doing that yet?
/usr/sbin/jamf deleteAccount -username $1 -deleteHomeDirectory
I've had issues in the past when simply running an rm across the last logged in user.
Wouldn't it be better to randomize the UID rather than mapping each account to the same one?
can you not add a unique UID for each user record in ldap? Like use a script to populate an ldap attribute with a unique id and map to that? That would probably be the best solution
@mm2270 you can statically map UID's like this
Thats some old school type stuff I remember doing when I was integrating 10.2 with Novel and needing to do custom LDAP mappings
  • June 5, 2015
@mm2270 We currently do not have a unique number in our LDAP for every object. That is the main issue. So we are trying work around that by using the same number for everyone because I do not know how to make it randomly assign one. @rhysforrester do you know how to make it random? In the screenshot above, it is that UniqueID mapping I would need to map to something that says randomize. @c0up3 I tried you settings with the +0 they didn't work. Is there more to that script? I don't see what part of it would delete the accounts.
  • June 9, 2015
here is full script: sorry i dont know why it didn't copy correctly. Don't forget though, my script deletes any non admin (>1000) account if you have not logged in for 7 days.
I didn't write this and wish I could remember where I got this to give them kudos....
userList=`dscl . list /Users UniqueID | awk '$2 > 1000 {print $1}'`
        find /Users -type d -maxdepth 1 -mindepth 1 -not -name "*.*" -mtime +7 | grep "$a"
            dscl . delete /Users/"$a"  #delete the account
            rm -r /Users/"$a"  #delete the home directory
done
  • June 23, 2015
@rhysforrester - How would you randomize the UID? Do you know how?
  • June 23, 2015
@calumhunter So your screenshot is exactly what I am trying to do. It works for one user. The next user logs in and has permission errors. It seems it is not clearing out the record of the old user with the same UID.
My logout script has the following in it to help clear out the record of the logged in user:
USER=$1
userHomeDir=/Users/$USER
dscl . -delete /User/$USER
/bin/rm -rf $userHomeDir
/usr/bin/kill all -u $USER
/usr/bin/killall Directory Service - This seems to make things worse, may remove.
What else can I add to remove all records of the first user logging in with the same UID.
  • June 23, 2015
maybe typos are your problem? Here are two that stand out to me.
dscl . -delete users/$USER
killall -u $USER
I would not killall directory service, which really probably is not working because you need to escape the space in that command.
  • June 23, 2015
and why map the UID at all and not just let different users login and let the UID get created automatically?
@nessts the OP is connecting to an LDAP server, the UID needs to be mapped to an attribute in LDAP or statically mapped via the mappings in the LDAP plugin in Directory Access. The UID does not automatically get created.
@pblake what OS are you doing this on? 10.10?
How are you running the logout script?
can you post your exact logout script with correct formatting? (HINT: theres a button in the post response window that looks like > _ click that and put your script between those tags and it will format it nicely
  • June 23, 2015
@nessts - the typos were here not in the script.
@calumhunter Below is the script. I am using iHook so some of the echo stuff is from that.
USER=$1
manageDir=/Library/Management
scriptDir=${manageDir}/bin
backupDir=${manageDir}/UserBackups
scriptLogFile=${manageDir}/bin/log/logout-wrapper.log
activityLogFile=${manageDir}/bin/log/activity.log
usageLogFile=/Users/$USER"/Library/Preferences/*Usage.log"
usageLogDir=${manageDir}/bin/log/usage
labUser=labuser
labGroup=labgroup
templateHomeDir=/Users/labuser
echo %WINDOWLEVEL HIGH
echo %UIMODE AUTOCRATIC
echo "Logging Out..."
if [ -z "$USER" ]
then
    echo "No user specified!" >> $scriptLogFile
if [ $USER = "admin" -o $USER = "labuser" ]
then
# tar up files of user logging out to a backup directory
cd /Users/$USER && tar zcf ${backupDir}/$USER.`date "+%F_%H.%M.%S"`.tgz Desktop Documents Downloads
cd /
dscl . -delete /Users/$USER
/usr/bin/killall -u $USER
echo "$USER logged out at $(date) on $(hostname)" >> $activityLogFile
echo %100
os version?
should be
what are you user names? do they contain spaces? special characters? I generally always double quote my variables just in case ie.
userHomeDir="/Users/$USER"
and
/bin/rm -rf "$userHomeDir"
  • June 23, 2015
@calumhunter There are no spaces or special characters in the usernames.
That typo of Users/$USER was only above, not in the actual script.
I am testing with a few accounts:
pt2415
pt2419
pt2421
pt2415 will work fine. Then the next ones who log in get a permissions error.
"The home foler for user "pt2419" isn't located in the usual place or cannot be accessed."
I have UniqueID mapped to #99999998. It seems the dscl . delete doesn't remove all records of that being used by pt2415 the first time.
  • June 23, 2015
10.10.3
  • June 23, 2015
@pblake
As per nessts, there's a core implementation error here.
  • June 23, 2015
glad I am not the only one who thinks so. :D
  • June 23, 2015
@chris.hotte & @nessts
I agree with you but this is the mandate from my Identity Management team, I don't control LDAP. I wish I worked in an Active Directory world, but I dont :(
I need to find a way to either flush the previous login or set it to randomly generate uid on login.
