Help running login script as user
donmontalvo
Forum|alt.badge.img+36
The attached script runs fine when manually invoked...how can I get it to run as a login script as the current user (not as root)?
IFS=':'
for pvm_file in $( "/Users/Shared/Parallels" | grep .pvm | tr '
' ':' ); do
prlctl register "/Users/Shared/Parallels/${pvm_file}" --preserve-uuid no
done
unset IFS
I know I need to add $3 but how do I add it to this script?
TIA,
Don
Best answer by jarednichols
Capture the owner of /dev/console with
user=`ls -la /dev/console | cut -d " " -f 4`
and then ```
sudo -u $user <command>
Larkin will tell you to use awk. I'll tell you to use cut.
  • April 24, 2012
Can you explain briefly what the above script is doing? I don't use Parallels, so I'm not familiar with some of the commands in there. Is it providing a registration key for the software?
use a launchagent instead. do you really need to do this on every login?
and then ```
or use a launchagent, and it will run as the user on login without having to determine who the user is.
to clarify, if all you need to do is run the script above on login with no changes, do something like the following:
  1. save the script to /usr/local/bin and make it executable.
  2. drop in a launchagent that calls the script under /Library/LaunchAgents with the proper permissions.
the launchd plist might look like this:
<plist version="1.0">
<dict>
    <key>Label</key>
    <string>com.company.something</string>
    <key>LowPriorityIO</key>
    <true/>
    <key>Nice</key>
    <integer>20</integer>
    <key>ProgramArguments</key>
    <array>
        <string>/usr/local/bin/something.sh</string>
    </array>
    <key>RunAtLoad</key>
    <true/>
</dict>
</plist>
donmontalvo
Sorry for the confusion, I spun off the question from the previous thread. The tool being used is prlctl which is installed by Parallels and allows manipulation of virtual machines, settings, etc.
http://kb.parallels.com/en/112013
We are using the Parallels Auto Deploy wrapper package to deploy Parallels 7 along with virtual machines (requires volume license key of course).
http://www.parallels.com/products/enterprise/desktop/
The package works fine for all existing users. It registers the deployed virtual machines, so when the user launches Parallels 7 it displays the virtual machines that we deployed, no action needed on the user's part.
However...it doesn't do anything for future users. So when a new user logs on to the Mac for the first time and launches Parallels he/she is prompted to:
1. Navigate from ~/Documents/Parallels (the consumer default) to /Users/Shared/Parallels (the enterprise default).
1. Select the virtual machine and click ADD button to register it in Parallels.
  1. User is then prompted for admin rights to register the virtual machine...(NOOOOOO!!!!!!!).
Vlad's script eliminates the need for user interaction... :):):)
What Vlad (Parallels enterprise engineer) did was provide a script that has to be run once as the user. The script inventories all virtual machines in /Users/Shared/Parallels and registers them for that user. The beauty of the script is it is non-distructive...so if a virtual machine is already registered it exits silently...and if the user registered any virtual machines that are not in the /Users/Shared/Parallels default path it won't effect those either.
Jared, thanks for the pointer...I'll test this and shout back.
PS, we plan to run this using Casper policy set to run the script Once Per User (so no need for launchd).
Don
donmontalvo
@jarednichols Just curious...isn't $3 or $userName supposed to allow us to run script as current user?
Don
it's not confusing. if you use a launchagent, you won't need to know the currently logged in user's shortname or any future local or network account names, for that matter. it will fire on login, regardless. for things like this, i don't see any need to use a casper policy that mounts the casper share just to run a script. if it needs to work locally, keep it local.
i just figured i'd give you an alternative approach. "teaching to fish," etc.…
donmontalvo
@rockpapergoat Thanks, the launchd suggestion looks great, but we want to try to use the existing Casper functionality first (run script Once Per User), and if the functionality isn't already there we can circle back and try the other methods like launchd. I'm going to try to add the lines recommended by Jared and will shout back with results.
sort of my point: the casper approach is more work.
donmontalvo
@rockpapergoat Agreed, a bit more work to set up...but in our case easier to manage (especially whn you have staff all over the world who share the same tools). ;)
Forum|alt.badge.img+31
  • April 24, 2012
Hey everyone,
I think maybe a good feature request would be to run a policy as a user, then maybe the Casper Framework down the road can have launch agents run your script like Nate mentioned in this thread. I think this would be a totally awesome ability, if you all feel the same please request it.
Using the current options, if you enable login hooks in the framework you can use the $3 to option to return the current logged in user. You can also set manual parameters to the script in Casper Admin to script to run certain things or set variables.
I think launch agents are a good idea, but the one caveat is they would always run at that user's log in (or any user login depending on how you run the agent) where Casper can limit it to run once per a user and then be done.
Thanks,
Tom
donmontalvo
@tlarkin Hi Tom, thanks...so back to my original question:
Based on Jared's response, I wonder if we can use this:
sudo -u $3 <command>
But how do you wrap this around the above script? Calling all script gurus.. :D
Don
Forum|alt.badge.img+20
  • April 24, 2012
Could you maybe package the script as a postinstall script and then deploy it at login?
@matt, that's more complicated. i wouldn't do it that way.
@don try "sudo -u $3 prlctl…"
do you have anyone on staff who can help you write these things? it feels like posting to a community board every step of the way is pretty inefficient. or just try some stuff till it works.
donmontalvo
@rockpapergoat The questions is how to use $3 on the script posted at the top of this thread. Unfortunately the below won't work since we're not running a single line command:
I'll open a ticket with JAMF, they should have the answer on how to run a shell script as a user, one time, at login. ;)
Don
just su $userName. Policies run as root, so you don't need a password to switch to any less privileged user.
Then just run the rest of the script. It's how I get around Integrated Colors shtty sht sht sht ColorEyes installer
or you can use applescripts do shell script commands and port your script to applescript, and have a bash wrapper that calls osascript using the HEREDOC method. It's what I use to unlock a users desktop automatically... Ex below:
osascript<<ENDDetectUnlock
set unlockAfter to 1202 -- The desktop is set to lock after 20 minutes of inactivity, however if the mouse is moved or keyboard pressed immediately after the screen saver starts, the Mac will NOT prompt for a password, so set the locked desktop check to 20 minutes and 2 seconds (1202 seconds)
tell application "System Events" to set screenSaverActive to (exists process "ScreenSaverEngine") -- the user may have their screen saver start before the system is idle for 20 minutes which will also lock the computer, so we need to check for this as well, since the system may not be idle for ~20.033 minutes yet
set idleTime to do shell script "echo $((`ioreg -c IOHIDSystem | sed -e '/HIDIdleTime/ !{ d' -e 't' -e '}' -e 's/.* = //g' -e 'q'` / 1000000000))" -- get the system idle time in seconds
if ((idleTime as integer) ? unlockAfter) or screenSaverActive then
    tell application "System Events" -- if the system is idle for ~20.033 minutes or more OR the screen saver is active, unlock the screen by simulating the user pressing the space bar and unlocking the screen with their password (except we do it as the admin)
        keystroke space
        delay 1
        keystroke tab
        delay 1
        keystroke "admin"
        delay 1
        keystroke tab
        delay 1
        keystroke "password"
        delay 1
        keystroke return
    end tell
    do shell script "echo System did not need unlocking."
end if
ENDDetectUnlock
The <<EndDetectUnlock tells Bash to run every command until the next occurrence of ENDDetectUnlock using applescript
I think you would need to add the "sudo -u $3" part in front of each line of your original script that you wish to run as the logged in user. You only will be using that script in your Casper policy instead of using a script to call your original.
this bikeshed is huge, man.
you only need to run one line of that script as another user, so try my suggestion and see if it gets you there.
you don't need to be another user to iterate through the files or set IFS, just to run prlctl. you don't need to su to the user or use applescript here, either.
i'm tapped out on this one. as digital underground says, "do what cha like."
bentoms
Forum|alt.badge.img+35
  • April 24, 2012
Sounds like a vote up for the below FR: Allow policies to be run once per user per computer.
https://jamfnation.jamfsoftware.com/featureRequest.html?id=45
talkingmoose
Sorry for jumping into the middle of the conversation.
I have to agree with Nate. This is a job for a launch agent. The purpose of a launch agent is to do or run something at login as the current user. It was designed to address the problem at hand.
Sometimes Casper just doesn't need to be part of the solution.
donmontalvo
@jarednichols Dude, I owe you big time...works like a charm:
IFS=":"
for pvm_file in $( ls "/Users/Shared/Parallels" | grep .pvm | tr 'n' ':' ); do
sudo -u $user prlctl register "/Users/Shared/Parallels/${pvm_file}" --preserve-uuid no
done
unset IFS
Guys, thanks for all the ideas and suggestions.
Don
  • April 24, 2012
Hahaha I just caught this. I only use awk because I use it more frequently than cut. Otherwise if it gets the job done I could care less.
Cheers
-Tom
donmontalvo
Thomas, for what it's worth, I just tested your method and it works too. Is it possible for you and Jared to share an ether beer? :)
I passed the completed script to Vlad at Parallels so they can share it along with the Parallels Auto Deploy wrapper package (new one will be released soon that fixes the reported issues).
Don
Cookie policy
Cookie settings
