Help with script
  • January 26, 2017
  • 10 replies
  • 123 views
I am trying to run a script to remove an app from our Macs. When I run it, the killall lines work and the rm -r lines do not. The error I get is, "No such file or directory". If I run any of the commands alone in Terminal, they all work. Any ideas what I am doing wrong?
Here is the script:
!/bin/sh
sudo killall EquitracLoginController
sudo killall EQLoginController
sudo rm -r /Applications/Utilities/EquitracPrinterUtilityX.app
sudo rm -r /Library/Printers/Equitrac/
sudo rm -r /Library/Application Support/Equitrac/
  • January 26, 2017
Without being on the computer, it's hard to troubleshoot. But, if you're running the script from the JSS, you don't need sudo, as everything runs as root. It may be breaking because it's expecting you to authenticate.
If you're installing Equitrac as a package, from Casper Imaging or Self Service, you could index the package, then check the Allow package to be uninstalled box. That might be a more complete deletion.
  • January 26, 2017
At this point, I am just testing the script in the Terminal on a machine that has items listed in the directories targeted in lines 3-5.
Are you suggesting that I remove sudo and attempt running the script from the JSS?
  • January 26, 2017
Either that, or get rid of the sudos in the script, and use sudo to run the script itself.
As quoted from askubuntu:
It is rarely a good idea to have sudo inside scripts. Instead, remove the sudo from the script and run the script itself with sudo:
sudo myscript.sh
That way, all commands within the script will be run with root privileges and you only need to give the password once when launching the script.
Bonus tidbit: If you need a particular command within the script to be run without sudo privileges, you can run it as a regular user:
sudo -u username command
  • January 26, 2017
So, your script should be:
Then just run it with:
sudo sh ./dieEquitracDie.sh
  • January 26, 2017
Thanks. I tried your script version and I still get the "No such file or directory" error.
  • January 26, 2017
The error is originating here:
Ref: Word Splitting
The interpreter is reading that line as sudo rm -r /Library/Application.
Assuming you've followed JayDuff's instructions re: sudo, you'll want to change the above line to either:
or
rm -r "/Library/Application Support/Equitrac"
  • January 26, 2017
Duh. Good spot, @grepoli !
  • January 26, 2017
Thanks @grepoli!
Using the same suggestion, I am unable to execute this line:
How should I handle that line?
  • January 26, 2017
@tomhastings
Assuming you're running this script multiple times on the same computer, that file was already deleted the last time you ran the script during testing. Without the force (-f) option, the rm command fails when it encounters a nonexistent file/directory. Add that option, and for peace of mind, add the verbose (-v) option as well.
Thus:
#!/usr/bin/env bash
# Kill processes if running
killall EquitracLoginController EQLoginController
# Remove the app and installed components
rm -rfv "/Applications/Utilities/EquitracPrinterUtilityX.app"
rm -rfv "/Library/Printers/Equitrac"
rm -rfv "/Library/Application Support/Equitrac"
sudo chmod +x /path/to/script to make it executable, then run with sudo /path/to/script
  • January 26, 2017
Thanks for all the help! Everything is working.
