How to Create a Jamf Daemon or Agent for when users click on Jamf connect to make them an admin
  • Mar 26, 2024 4:05 PM UTC
  • 144 views
Does anyone have a script or know of an agent/daemon that I can use or edit to alert for when a user clicks on - request admin privileges on Jamf connect?
  • Mar 26, 2024 6:07 PM UTC
It is actually a new feature in *Jamf Connect version 2.33*. You use the
Jamf Connect Configuration Tool there is a new feature under *Connect *tab
section *Temporary User Permissions* where you enter your desired settings.
Upload to Configuration Profile or add to existing one.
*Jamf Connect - Introducing Privilege Elevation*
*Jamf Connect* - Introducing Privilege Elevation, the ability to grant
Temporary User Promotion from Standard User to Admin User. This is a new
Jamf Connect feature and I wanted to share this information with you.
https://www.jamf.com/blog/privilege-elevation-macos-security/
Debbie Michels
Apple Specialist
ITS Information Technology Services
Bergen Community College
Pitkin Building - Room A236
400 Paramus Road, Paramus NJ 07652
dmichels@bergen.edu
(O) 201-879-1694
  • Mar 26, 2024 6:21 PM UTC
Debbie Michels
Apple Specialist
dmichels@bergen.edu
(O) 201-879-1694
Thank you and you know what, I'm sorry I just realized I did not ask the question correctly. I basically want to be notified when a user clicks on that admin window. I have it in my enviornment running, I have a script to notify me on Teams, the problem is I don't have an agent or daemon to trigger to let me know when a user clicks on it. Thank you for responding by the way!
