how to disable apple intelligence and chatgpt in macOS 15.1 using jamf pro
  • Oct 30, 2024 12:23 AM UTC
  • 37 replies
  • 2281 views
Show first post
ianatkinson
  • Jan 23, 2025 2:55 PM UTC
I would love to know if you have had success with this. I'm in a similar situation: setting up a new Sequoia lab and the AI popup (and "Welcome to Mac" screen) at every login is not ideal.
Actually I may have figured this out while typing this reply: If you don't have success with the restrictions profile, check your Prestage Enrollment for the lab Macs. Make sure the Intelligence box is checked (so the setup pane is skipped) under Setup Assistant Options.
I haven't had success no :(
I've added a combination of
1) the Rokas profile above
2) a new config profile with restrictions payload (only place restrictions is used) with all AI stuff off
3) AI stuff off in the prestage
... still getting the AI setup window on login
azercher
  • Jan 23, 2025 3:05 PM UTC
The only way I have been able to disable Apple Intelligence is by applying a restrict Siri app and this completely disables access to AI. I still get prompts for it but cannot configure or use it.
  • Jan 23, 2025 8:06 PM UTC
Sorry if this seems obvious, but did you erase the machine and go through setup again after disabling the AI stuff in the prestage enrollment? It only gets those settings at the enrollment during Setup Assistant. I'm pretty sure this is the specific thing that fixed the login issue for me, considering I have actually removed the various restrictions and still don't see the setup pane at login.
I do still see the "Ready for Apple Intelligence" notification once logged in, so that's the next thing I have to suppress... but at least it's not gumming up the entire login & user profile config.
ianatkinson
  • Jan 27, 2025 8:16 AM UTC
No, we've got 800 machines in JAMF and are in the middle of term I can't just flatten everything at this stage to solve this issue.
ianatkinson
  • Jan 28, 2025 3:21 PM UTC
OK so as suggested I've just flattened one of our machines and the prompts are now gone, I had also removed the extra file Rokas had provided. So the steps for getting rid of the prompts entirely seem to be:
1) turn it off in prestage
2) deploy a restrictions profile with it turned off
3) flatten computer so it goes back through prestage
It's a farce that things seem to happen in prestage that then permanently affect the machine as that's just supposed to be for skipping setup screens not enduring config? Just another MDM mystery I suppose, I'm pretty fed up with it all at the moment! We will have to flatten everything in Summer hols and put up with it until then.
TomRWSmith
  • Jan 30, 2025 2:18 PM UTC
You can create Config Profiles to restrict Apple Intelligence from appearing when upgrading to 15.0 - 15.1.1 and another Config Profile when upgrading to 15.2 as Apple push this out again when upgrading from 15-15.1.1 to 15.2.
I created a Smart Group for both 15.0 - 15.1.1 & 15.2.
I followed this guide and this removed the Apple Intelligence pop-up after upgrading.
https://derflounder.wordpress.com/2024/12/12/suppressing-the-apple-intelligence-pop-up-window-with-a-configuration-profile-on-macos-sequoia/
  • Jan 30, 2025 11:53 PM UTC
jho
what about using this in a CP
  • Feb 3, 2025 7:57 PM UTC
jho
I had that (and the checkbox for Disable Apple ID) checked in my login window profile and still saw the AI setup screen. I am pretty confident the Intelligence setup pane in the Prestage is what was triggering it.
However, check out TomRWSmith's comment below. I haven't tested it myself, but it looks like exactly the kind of config profile you would need to use to disable the AI setup without requiring the re-image.
ianatkinson
  • Feb 12, 2025 11:19 AM UTC
Can confirm that adding this mobileconfig seems to get rid of the AI setup screen even without having flattened the machine, however there is still a 'welcome to mac' screen would be great to get rid of that also
TomRWSmith
  • Feb 13, 2025 12:28 AM UTC
Try this, this is what I use and it's removed Welcome to Mac.
https://derflounder.wordpress.com/2025/01/04/suppressing-the-welcome-to-mac-screen-with-a-configuration-profile-on-macos-sequoia/
ianatkinson
  • Feb 13, 2025 8:56 AM UTC
oh excellent thank you, I think that should get it all finished off
iOllie
  • Sep 10, 2025 1:39 PM UTC
Here is my updated version of the “Disable Apple Intelligence and ChatGPT” configuration profile, which includes the new restrictions announced at WWDC 2025. For the full list of restrictions, please refer to the official documentation already shared: https://developer.apple.com/documentation/devicemanagement/restrictions
<plist version="1.0">
<dict>
<key>allowAppleIntelligenceReport</key>
<false/>
<key>allowExternalIntelligenceIntegrations</key>
<false/>
<key>allowExternalIntelligenceIntegrationsSignIn</key>
<false/>
<key>allowGenmoji</key>
<false/>
<key>allowImagePlayground</key>
<false/>
<key>allowImageWand</key>
<false/>
<key>allowMailSmartReplies</key>
<false/>
<key>allowMailSummary</key>
<false/>
<key>allowNotesTranscriptionSummary</key>
<false/>
<key>allowSafariSummary</key>
<false/>
<key>allowVisualIntelligenceSummary</key>
<false/>
<key>allowWritingTools</key>
<false/>
</dict>
</plist>
