How to Rotate Recovery Lock Password 1 Hour After Viewing for Existing Enrolled Macs?
  • Sep 28, 2026 1:38 PM UTC
  • 8 replies
  • 239 views
bhejmady1992
Hi Jamf Community,
I’m looking for guidance on implementing Recovery Lock password rotation for existing Apple Silicon Macs already enrolled in Jamf Pro.
Current Setup
For newly enrolled Macs, we have enabled Recovery Lock through PreStage Enrollment.
This works as expected:
  • Recovery Lock password is automatically generated.
  • The password can be viewed from the device inventory in Jamf Pro.
  • After the password is viewed, Jamf automatically rotates it after approximately 1 hour.
Challenge with Existing Macs
We also have a number of Apple Silicon Macs that were enrolled before Recovery Lock was enabled in our PreStage configuration.
For these existing Macs, I created a script that uses the Jamf Pro API with Client ID and Client Secret authentication.
The script successfully:
  1. Authenticates to Jamf Pro.
  2. Retrieves the Mac’s Management ID.
  3. Generates a random Recovery Lock password.
  4. Sends the SET_RECOVERY_LOCK MDM command.
  5. Successfully enables/updates Recovery Lock on the Mac.
This part is working as expected.
Problem
The issue is that Recovery Lock passwords set through the API do not appear to inherit the same automatic password rotation behavior as Recovery Lock configured through PreStage Enrollment.
For example:
PreStage-enrolled Mac:
Password viewed → Wait 1 hour → Jamf automatically rotates password
Existing Mac with Recovery Lock set through API:
Password viewed → No automatic rotation
What I’m Trying to Achieve
I would like to reproduce the PreStage behavior for our already-enrolled Macs:
Admin views Recovery Lock password in Jamf → Detect viewing event → Wait 1 hour → Generate new password → Send SET_RECOVERY_LOCK → Password rotated
Is there a supported way in Jamf Pro to detect when a Recovery Lock password has been viewed?
I’m particularly interested in whether this can be achieved using:
  • Jamf Pro API / API audit history
  • Jamf webhooks
  • Jamf Routines
  • Smart Groups
  • Extension Attributes
  • Jamf automation/workflows
  • Another supported method
Ideally, I would like to detect the password-view event and then trigger another SET_RECOVERY_LOCK command one hour later.
Has anyone successfully implemented automatic Recovery Lock password rotation after viewing for existing enrolled Macs?
If there is an API endpoint, audit event, script, or workflow that can detect when the Recovery Lock password was viewed, I would really appreciate an example or some guidance.
Thanks in advance!
bhejmady1992
  • Sep 29, 2026 9:25 AM UTC
​@mvu ​@leecacioppo ​@Chubs ​@dletkeman ​@BookMac : Could you please help here.
WickedSmaht
  • Sep 29, 2026 10:25 AM UTC
Thanks for that,
Great write up!
Chubs
  • Sep 29, 2026 1:04 PM UTC
I’m almost positive it can be achieved with the new routines that has yet to be released due to the “open nature” of how it works.
Otherwise in the interim - if you have power automate, n8n, or something similar - then a solution can be put together for it.
dletkeman
Forum|alt.badge.img+19
  • Sep 29, 2026 1:48 PM UTC
Hi — I haven’t implemented this workflow myself. This is based on Jamf docs, older Nation threads, and public write-ups I found (including with AI-assisted search). Treat it as a research summary, not a battle-tested runbook.  I’m also using AI to summarize and format everything so treat with a grain of salt.
Short version: the ~1 hour rotate-after-view behavior is tied to PreStage + a Jamf-generated random Recovery Lock password. SET_RECOVERY_LOCK via the API will set/update the lock and store the password in inventory, but it does not appear to enroll that record in Jamf’s scheduled rotator. There also does not appear to be a supported “Recovery Lock password was viewed” event you can hang automation on.
Why PreStage machines rotate and API-set ones don’t
Jamf Pro 10.33 added Recovery Lock password rotation:
Password rotation applies to passwords that are randomly generated by Jamf Pro. Viewing the password in the computer’s inventory information automatically enables Jamf Pro to generate a new, random password for that computer 60 minutes after the password was viewed.
https://docs.jamf.com/10.33.0/jamf-pro/release-notes/New_Features_and_Enhancements.html
That matches what you see on PreStage-enrolled Macs.
Setting the lock after enrollment is a different path. Jamf’s article covers POST /api/v2/mdm/commands with commandType: SET_RECOVERY_LOCK and newPassword. That works (as you’ve already proven). It stores the password in Jamf. It does not say that this also starts the 60-minute rotation timer.
https://learn.jamf.com/en-US/bundle/technical-articles/page/Recovery_Lock_Enablement_in_macOS_Using_the_Jamf_Pro_API.html
This same gap showed up on Nation back in 2022. On the “Recovery Lock API” thread, the consensus was that key rotation after view was only supported when Recovery Lock was enabled through PreStage:
https://community.jamf.com/general-discussions-2/recovery-lock-api-26473
Dan Snelson ran into it from the other direction: view the recoveryOS password via API / Self Service, then ask Jamf to do the scheduled rotate. He confirmed with Jamf Support that GUI view → scheduled rotate worked, but SetRecoveryLock - Scheduled was not available on the API, and opened feature request JN-I-25769:
https://snelson.us/2022/06/view-recoveryos-password/
Detecting “password viewed”
I could not find a Recovery Lock equivalent of LAPS audit history.
LAPS does expose who viewed the password and when:
GET /api/v2/local-admin-password/{clientManagementId}/account/{username}/{guid}/audit
https://developer.jamf.com/platform-api/reference/get_v2-local-admin-password-clientmanagementid-account-username-guid-audit-1
Recovery Lock only has the view endpoint itself, e.g.:
GET /api/v2/computers-inventory/{id}/view-recovery-lock-password
https://developer.jamf.com/jamf-pro/reference/get_v2-computers-inventory-id-view-recovery-lock-password
Calling that endpoint is viewing the password. It is not a history feed.
Webhooks also don’t list a Recovery Lock view event. The documented events are things like ComputerAdded, ComputerCheckIn, ComputerInventoryCompleted, RestAPIOperation, etc.:
https://developer.jamf.com/jamf-pro/docs/webhooks-1
Inventory/Smart Groups can tell you Recovery Lock is enabled or not, not when the password was last shown:
https://learn.jamf.com/en-US/bundle/technical-articles/page/Jamf_Pro_Reporting_Capabilities_for_Apples_macOS_Security_Features.html
Jamf Routines templates (as of the public list I saw) are things like Slack/Teams notify, rename, restart, update EA — not Recovery Lock view detection:
https://www.jamf.com/blog/jamf-routines-workflow-automation-introduction/
So I would not plan on:
  • Jamf webhooks
  • Smart Groups / EAs
  • Routines
  • a public Recovery Lock audit API
…to fire “wait 1 hour, then SET_RECOVERY_LOCK.”
RestAPIOperation might fire if someone hits the view endpoint via API. GUI “Show Password” is a different path and is not documented as a webhook. Even if it showed up in audit logs, that doesn’t look like a supported automation trigger the way LAPS audit is.
Practical options for already-enrolled Macs
1. Don’t try to clone PreStage 1:1.
Treat the API-set cohort as “set unique random password + rotate on a schedule + rotate again after any real use.”
Scheduled SET_RECOVERY_LOCK is a common pattern. One public example is the Inetum-Poland GitHub Action (OAuth client credentials, optional Smart Group scope, issues SET_RECOVERY_LOCK):
https://github.com/Inetum-Poland/jamf-recovery-lock-rotation
There are also older group/search-based scripts for “we enrolled before PreStage had Recovery Lock,” e.g.:
https://github.com/chrisgzim/Jamf-API-Recovery-Lock-by-Group
https://gingerscripting.com/setting-an-apple-silicon-recovery-lock-password-through-the-jamf-api/
Use /api/v2/mdm/commands rather than the old /api/preview/mdm/commands path.
https://community.jamf.com/general-discussions-2/set-recovery-lock-password-api-deprecated-32533
2. If you really need “view starts a 1-hour clock,” wrap viewing.
Don’t have techs use Inventory → Show Password for those legacy Macs. Put view behind an internal tool / Self Service / helpdesk script that:
  1. Calls view-recovery-lock-password
  2. Shows the password
  3. Records {managementId, viewedAt}
  4. One hour later sends a new random SET_RECOVERY_LOCK
That’s basically Snelson’s idea, except you own the scheduler because Jamf’s scheduled command isn’t on the API.
Keep API credentials off managed Macs. Jamf explicitly recommends against running credentialed scripts from the fleet in the Recovery Lock API article above.
3. Ask Jamf for the product fix.
Useful request text:
  • Apply the existing 60-minute rotation-after-view to Recovery Lock passwords set via SET_RECOVERY_LOCK, not only PreStage-generated ones
  • Expose SetRecoveryLock - Scheduled (JN-I-25769)
  • Add a Recovery Lock view-audit API like LAPS
Re-enrolling those Macs through ADE/PreStage with random Recovery Lock would get native behavior, but that’s usually a much bigger operational cost than scheduled API rotation.
I think ​@Chubs is probably right with what he says.
mvu
  • Sep 29, 2026 1:49 PM UTC
To be honest, we don’t check that box in our prestage instance. But your write up made me think! 🤔
Did you reach out to Jamf support yet?
bhejmady1992
  • Sep 29, 2026 2:24 PM UTC
Update: I’ve submitted a feature request with Jamf for this functionality.
The request is to support automatic Recovery Lock password rotation after the password is viewed for existing/enrolled Apple Silicon Macs, including devices where Recovery Lock was set using the Jamf Pro API.
If you have the same requirement, please upvote the feature request to help increase its visibility:
JPRO-I-2278: https://ideas.jamf.com/ideas/JPRO-I-2278
Thanks for your support!
dletkeman
  • Sep 29, 2026 2:26 PM UTC
Upvoted!
BookMac
  • Oct 2, 2026 12:45 PM UTC
Upvoted!
Sorry for the delay, i was in a Jamf 270 Course this week and unfortunately i also don’t have a solution for that. :(
