How to uninstall BOX drive using script
  • September 21, 2021
  • 5 replies
  • 21 views
I have tried below one but isn't working, Any ideas?
logged_in_user=
$( scutil <<< "show State:/Users/ConsoleUser" | awk '/Name 😕😕 && ! /loginwindow/ { print $3 }' )
appname="Box"
testDirectory="/Applications/${appname}.app"
if [ -d "${testDirectory}" ]; then
echo "${appname} is installed; quit if running ..."
     if [[ $(ps axc | grep "$appname") != "" ]]; then
     echo "Box running, Quitting ..."
     sudo /usr/bin/osascript -e 'quit app "'"${appname}"'"'
     sudo pkill $appname
     echo "Box not running, exiting..."
sudo -u $logged_in_user /Library/Application\\ Support/Box/uninstall_box_drive
  • 365 replies
Does the Box uninstaller not work?
/Library/Application Support/Box/Uninstaller
Thanks for your response Andrew.
Have been tried and it's not working.
geoff_widdowson
Here is my working policy
  • 20 replies
  • November 16, 2021
Thanks @geoff_widdowson! In my initial testing I didn't include the kill process for Box. But not only that, I was running
/Library/Application\\ Support/Box/uninstall_box_drive (without the _r) (just as the Box article states) as a policy command, and it kept erroring out mentioning not to use Sudo. I wasn't entering sudo in the command at all. Anyways, your process seemed to have uninstalled Box, and so thanks for your help.
AVmcclint
Forum|alt.badge.img+21
  • 1043 replies
  • April 13, 2022
Your policy didn't work for me (as of version 2.26.330). It still kept saying not to run it with sudo. I ended up removing the "Search for Process" entry and the "kill process if found". I used this in the Command box:
killall Box ; /Library/Application\\ Support/Box/uninstall_box_drive_r
and that worked.
What is the difference between the 3 different uninstall tools in AppSupport/Box/?
Cookie policy
Cookie settings
