i need some help with an API script
  • Aug 25, 2022 5:21 PM UTC
  • 74 views
i have a computer extension attribute we use to set a computer's Role. its a drop down list. im trying to get a script to update that EA value in bulk off a .csv file of serial numbers.
im hitting a wall. i get no errors and it looks like it all runs fine, but it just wont update the EA value. i have the script running is a self service policy. i have pasted my script below. what do i have wrong?
also most of this is cut and paste from many other sources on the internet. mostly jamfnation
#!/bin/bash exec > /Library/pthsd/output.txt 2>&1 YourAPIUsername="$4" YourAPIPassword="$5" # This is your unix line ending formated csv file of serial Numbers # First Column is labeled serial INPUT=$(/usr/bin/osascript << EOF tell application "System Events" try set INPUT to text returned of (display dialog "Enter the path to the .csv file with serial numbers" buttons {"Cancel", "Enter"} default button 2 default answer "") end try end tell EOF) if [ "$INPUT" != "" ]; then echo "User input serial: $INPUT" else echo "User canceled. Exiting" exit 0 fi echo "path to csv is $INPUT" MacUserRole=$(/usr/bin/osascript << EOF tell application "System Events" try set MacUserRole to text returned of (display dialog "Enter the desired value for Mac User Role" buttons {"Cancel", "Enter"} default button 2 default answer "") end try end tell EOF) if [ "$MacUserRole" != "" ]; then echo "User input: $MacUserRole" else echo "User canceled. Exiting" exit 0 fi echo "Desired Mac User Role is $MacUserRole" # Set the file seperator to read the CSV correctly OLDIFS=$IFS IFS=, # JSS URL to PUT based on Serial Number. This could be "id" or "name" JSSURL="https://jss-01.pthsd.k12.nj.us:8443/JSSResource/computers/serialnumber/" # XML File that you're writing for each computer to upload using the API to make changes XMLFILE=/tmp/temp_api_values.xml # Basic Output in Terminal Window echo "Running" # Creates the XML File from above. Currently It's Blank touch $XMLFILE # This is where the magic happens. This is a bash loop. # In English. If the Input file doesn't exists, spit out an error [ ! -f $INPUT ] && { echo "$INPUT file not found"; exit 99;} #lets create the xml file echo "<computer> <extension_attributes> <extension_attribute> <name>Mac User Role</name> <value>$MacUserRole</value> </extension_attribute> </extension_attributes> </computer>" > $XMLFILE # Read the first column and make them usable as a variable while read serial # Do what I tell you to do do # Basic output in the shell window showing your progress # followed by the creation of the XML file using the variable and storing it in the XMLFILE location from above#. # This is the call to the API using cURL. It builds a unique URL for each Serial Number and PUT's the XML File in the request curl -sfku "$YourAPIUsername:$YourAPIPassword" "$JSSURL$serial" -H "Content-type: text/xml" -T $XMLFILE -X PUT done < $INPUT # Putting things back where we found them. IFS=$OLFIFS exit 0
  • Aug 25, 2022 6:49 PM UTC
nevermind. I was only trying to build this script because i didn't see the option in the MUT tool.    it turns out the feature i needed is in the MUT Classic tool.   so my initial problem is solved but i would still like to know why my script wasn't working.
skeenan07
  • Aug 25, 2022 7:56 PM UTC
You need to add "/subset/extensionattributes" after the serial number in the API command. Give this a try.
echo "$XMLFILE"  | curl -X PUT -sfku $YourAPIUsername:$YourAPIPassword -d @- "$JSSURL$serial/subset/extensionattributes" -H "Content-Type: application/xml"
