iPads not updating inventory over wifi, but do when connected using lightning-ethernet adapter.
  • November 18, 2022
  • 4 replies
  • 108 views
I have a weird issue where the inventory for my iPads isn't updating when on wifi, but it updates if I connect them to ethernet. They are all on iOS16.1.1, 9th generation wifi only - has anyone else seen this issue?
AtillaTheC
  • November 18, 2022
Potentially a port issue on the WiFi Vlan?
  • November 22, 2022
Check your DNS settings on WiFi versus Ethernet. Could be a DNS resolution issue resulting in the iPads cannot reach the Jamf server.
Or like AtillaTheC said, it could be a network port or restriction issue too.
  • November 23, 2022
Thanks for the replies, interesting issue where the DNS settings on the iPad (when on wifi) don't have the Search Domains area populated, but it is in there when I check the same setting on the ethernet connection. DNS servers ip's are populated and are the same on wifi and ethernet. I'll keep digging!
  • November 28, 2022
After much digging and testing, found that a previous employee had added a firewall rule blocking JAMF communicating with the generic account being used by the iPads. Removed the rule and iPads are now updating.
