Issue Connecting AD to Jamf Using Wizard
I seem to be stuck on a part of the setup trying to connect our Active Directory server to JAMF.
It keeps telling me that it can't find the account. I have all the right info for the domain. I have tried several known good accounts, but I still get "Could not find user".
Any leads or ideas to point me in the right direction would be great. Thanks!
Best answer by bvrooman
The "domain" field for authentication should contain the name of your domain, rather than the FQDN of a domain controller. In your example picture, the domain is probably ourdomain.com or OURDOMAIN.
  • May 5, 2017
mblair
  • May 5, 2017
This issue can b resolved by first joining the server that is hosting the JSS to the domain (Active Directory) .
bentoms
Forum|alt.badge.img+35
  • May 6, 2017
No need to bind the JSS host.
Try the manual option instead, never had luck with the builtin wizard.
Thanks @bvrooman ! using OURDOMAIN worked!
Thanks again!
