Do you happen to have a restricted software entry in place for Monterey for the computers that failed?
Was this on Intel or M1?
For M1 macs you need to modify the startosinstall command to pass administrator credentials on the machine
echo ${ADMINNAME} | '/Applications/Install\\ macOS\\ Monterey.app/Contents/Resources/startosinstall' --nointeraction --agreetolicense --forcequitapps --user ${ADMINPASS} --stdinpass
also for loggedInUser I recommend
loggedInUser=$([[ $3 ]] && echo "$3" || defaults read /Library/Preferences/com.apple.loginwindow lastUserName)
I did have one, but removed the scope prior to scoping this policy to machines. Another script runs before the above one which does call flushCaches and manage to remove & sync before this runs so it should have correctly removed any software restrictions on the local machine
All Intel based macs - haven’t tackled software updates on M1s yet, lol! Thankfully no m1s in the field… yet :)
Quick question, but do you know if the users are seeing the prompt come up and then it fails, or does the prompt not show at all? If it's the latter, then it may be an issue trying to display the Applescript dialog. Usually using the launchctl asuser syntax just as you have it works ok.
But honestly in this case as you aren't making use of any specific Applescript functions, like a drop down or user input, you'd be better off using jamfHelper for the dialog, since you don't need to have it run as the logged in user to work.
If the users ARE getting the prompt but then it fails, then clearly it's something in the startosinstall command it's not liking. Offhand, I don't see any issues with it though. The only real difference in my OS upgrade script is I also pass the --forcequitapps flag to startosinstall to make sure nothing blocks the upgrade.
They do get the popup, so I can isolate it to the startosinstall... I originally did have forcequitapps as part of that string, but in my testing removed it to see if it'd help it take which it hasn't yet. AppleScript seems to be fine, it just won't fully kick the installation off and seems to kill the process after that command is called
Not sure what happened, but I was able to fix this by just creating a new policy, copying everything over and deleting the old policy. Something must have become corrupted or sticky in that old one that was causing all the issues. Go figure, had nothing to do with the script.
Thanks everyone!
