Jamf Pro - brew upgade command using scripts section
  • Apr 3, 2024 5:35 AM UTC
  • 5 replies
  • 123 views
Hi Everyone,
I am new to Jamf Pro and i need a bash script to upgrade brew in our environment. Command i want to run - "brew upgrade xz". Could someone please help me with the shell script on priority? Thanks
adibue
  • Apr 3, 2024 1:26 PM UTC
Hi @rahz0092
Try this one:
#!/bin/bash # Check, where brew is installed brewbin=$(which brew); echo "$brewbin" # Variable for storing the current users name currentUser=$(scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ { print $3 }') # Run brew update and patch xz in user context /usr/bin/su "$currentUser" -c "$brewbin update" > /dev/null 2>&1 /usr/bin/su "$currentUser" -c "$brewbin upgrade xz" exit 0
However, this script does not check if homebrew is actually installed. So if it isn't, it will throw an error.
Hope this helps :-)
Regards, Adi
adibue
  • Apr 3, 2024 1:36 PM UTC
Forget the first one. Just noticed I did a mistake there with the brew checking.
This should do the trick (including detecting whether or not brew is installed):
#!/bin/bash # Variable for storing the current users name currentUser=$(scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ { print $3 }') # Check, where brew is installed brewbin="$(/usr/bin/sudo -i -u "$currentUser" /usr/bin/which brew)" if [ -z "$brewbin" ] then echo "brew not found. Cancel..." exit 0 else # Run brew update and patch xz in user context /usr/bin/su "$currentUser" -c "$brewbin update" > /dev/null 2>&1 /usr/bin/su "$currentUser" -c "$brewbin upgrade xz" fi exit 0
  • Apr 4, 2024 4:38 AM UTC
Thanks @adibue .. I will test it now and let you.
  • Apr 4, 2024 5:03 AM UTC
I have checked and script is working for me. Thanks man. @adibue
easyedc
  • Jun 25, 2024 8:47 PM UTC
Happened to come across this while working the same issue.  I did notice one thing to make it slightly more portable.
#!/bin/sh # Homebrew Updater.sh # # Created by Ed C on 6/24/24. # # Grabbed from https://community.jamf.com/t5/jamf-pro/jamf-pro-brew-upgade-command-using-scripts-section/td-p/313170 # https://docs.brew.sh/FAQ#is-there-a-glossary-of-terms-around # # Variable for storing the current users name currentUser=$(scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ { print $3 }') # Identify which Brew Formula to upgrade. If left blank, will attempt to update ALL formulae formula=$4 # Check, where brew is installed brewbin="$(/usr/bin/sudo -i -u "$currentUser" /usr/bin/which brew)" if [ -z "$brewbin" ] then echo "brew not found. Cancel..." exit 0 else # Run brew update and patch xz in user context /usr/bin/su "$currentUser" -c "$brewbin update" > /dev/null 2>&1 /usr/bin/su "$currentUser" -c "$brewbin upgrade $4" fi exit 0
Dropping in a variable=$4 allows you to just drop the formula into your policy's script field, or leave blank to apply to all.
