Jamf Pro Device Lookup- Spins and Spins and Spins
  • May 2, 2023 2:20 PM UTC
  • 5 replies
  • 84 views
Recently had a customer report a lost iPad so I did a search for the device to put it in lost mode. When trying to click into the device details, Jamf just spins endlessly. I was then able to click into several other devices with no issue. Restarted the browser, cleared the cache, restarted the computer etc- no change. This has happened before and is extremely frustrating.
Best answer by mvu
We ran into this quite a bit for our iOS devices. Jamf support will schedule an outage and resolve these records and others you may not know about.
As I understand it, this PI is resolved in the 10.46.0 update.
Wakko
Forum|alt.badge.img+21
  • May 2, 2023 2:27 PM UTC
I would reach out to support and have them check the record. Might be running into a PI issue potentially.
sdagley
  • May 2, 2023 2:57 PM UTC
What @Wakko said - when I see this issue with Computer records it indicates a corrupted record. If you're running on-prem Jamf Support can provide MySQL commands to resolved, and if you're Jamf Cloud hosted they'd have to apply the fix themselves.
  • May 2, 2023 2:59 PM UTC
Thanks folks, I'll reach out to them.
mvu
  • May 2, 2023 5:12 PM UTC
  • May 31, 2023 6:04 PM UTC
This issue was resolved after the 10.46.0 update.
