JamfAAD - Issue
  • May 31, 2021 12:25 PM UTC
  • 129 replies
  • 2060 views
Show first post
  • Jul 19, 2022 2:19 PM UTC
From my experience, deploying new profile will be suffice. Existing enrolled Macs won't be impacted. New users will have better experience registering their device. I would recommend two additional things to minimize JamfAAD prompts:
-Increase inactivity in macOS Connector to max (120 days)
-Plan schedule cleanup for macOS devices in Azure. Support case was lodged Microsoft where Intune compliant was not able access company resources. We had to delete old Mac devices (associated to users in Azure) which helped. Here is link to doc from Microsoft [Cause 6] - Troubleshooting Jamf Pro integration with Microsoft Intune - Intune | Microsoft Docs
That increase of the inactivity in the macOS Connector to 120 Days sounds perfect, can you provide any documentation on where to set this(or is it in the Microsoft Doc you linked previously)?
  • Jul 19, 2022 2:32 PM UTC
You may set in Jamf portal by going to Settings > Global Management > Conditional Access. Scroll down to bottom and there should be an option for Allowed Duration Of Inactivity. I believe, default value was 14 days.
This doc from Microsoft has helpful information for troubleshooting - Support Tip: Troubleshooting issues with macOS devices when using Jamf/Intune integration - Microsoft Tech Community. I would recommend bookmarking it
piotrr
  • Nov 11, 2022 8:50 AM UTC
Sorry to resurrect an old thread, but since we all shared this experience, this is the perfect place to share a related revelation. The original problem is more or less solved by now, with the webview option and both Edge and Chrome being much updated since, and in macOS 13 SSO integration with Company Portal.
However, I still have a few users, five as far as I know, whose computers will occasionally lose conditional access and when I check, their devices are removed from Intune, but present in AzureAD and Jamf (of course!). The temporary solution is to re-register them in Jamf Self Service with the special launch of Company Portal.
However, here's the interesting parts: They are all still using 13-inch Retina MacBook Pro with TouchID (Mid 2017). Five or six users with this model of Mac, in an environment with 85 Macs total, out of which only 15 active devices are this model. The devices are user-enrolled, no prestage or DEP/ADE.  Affected devices were all enrolled with Jamf in 2019: Three in January, one in March and one in May.
I haven't figured out the significance, but the correlation is too strong to be random chance, so I wanted to check if any of you are still having this issue, and if you have the same models in use.
husnudagidir
Hi Everyone,
My default browser right now is Chrome. but I don't have a problem with that. However, the following screen appears in some of the users I have installed Company Portal. When it approves this, it redirects to a page and asks the user to login to Microsoft. This happens randomly and is very disturbing for us. Does anyone know why this is happening and how to fix it?
