JavaScript for Automation (JXA) Scripting Support?
  • October 19, 2015
  • 0 views
Hi all,
I was wondering what the level of integration and support of Javascript (JXA, introdcued with Yosemite) for Scripting in Casper is.
Everything I have seen so far mostly talks about using bash/shell scripts. Is it possible to use Javascript instead and would you recommend doing so?
1 reply
bpavlov
  • 1206 replies
  • October 19, 2015
I can't speak specifically to that, but I imagine it should work as long as the OS supports it. You'll run into folks here who use AppleScript, Bash, Python, Perl, etc. I say use whatever you are most comfortable with and is most flexible across the operating systems you are supporting.
Cookie policy
Cookie settings
