Kernel Extension Enable for Camtasia System Audio Component
  • Jul 17, 2023 2:45 PM UTC
  • 0 replies
  • 46 views
Hi All,
I hope you're doing well. I have a question regarding the installation of Camtasia 2021 on more than 200 Macs in our organization. The audio system requirement for Camtasia indicates that we need to reduce security under Startup security utilities and allow user management of kernel extensions from identified developers.
I am interested in automating this process by deploying a configuration profile. If any of you have experience with this requirement and have successfully deployed a configuration profile to allow the audio extension, I would greatly appreciate your guidance and insights.
I have found that if the "reduce security" option is already enabled on all Macs, I can create a configuration profile and deploy it to allow the audio extension. If anyone has gone through this process or has any suggestions or best practices to share, please let me know.
https://support.techsmith.com/hc/en-us/articles/360055945312-M1-M2-Chip-and-the-Camtasia-System-Audio-Capture-Component
https://learn.jamf.com/bundle/technical-articles/page/Managing_Legacy_Kernel_Extensions_in_macOS_Using_Jamf_Pro.html#:~:text=(Optional)%20To%20approve%20specific%20kernel,Click%20Save.
