Key Value for Time Machine - Requires AC Power
Howdy Jamfers!
In our previous MDM with computers running Mojave, we were able to push out a Configuration Profile that would set Time Machine to run on AC Power. We copied over this .plist into Jamf in the Application & Custom Settings tab, but it is now seen an "Unknown Keys" for use with Big Sur. See Figure 1. below.
Does anyone know if there is an updated Key Value for the Preference Domain com.apple.TimeMachine.plist that will work with Big Sur?
Thanks in advance!
Aaron
Figure 1.
Best answer by ljcacioppo
I know we talked through this on the Chicagoland meetup, but figured Id post the schema that can be used to set this key here in case anyone looks through jamfnation and finds this
https://github.com/Jamf-Custom-Profile-Schemas/ljcacioppo-schemas/blob/main/com.apple.timemachine.json
ljcacioppo
  • November 2, 2021
  • Employee
  • November 3, 2021
Finally got a chance to test this today and it worked perfectly!
Aaron
