Lpadmin script and AD prompt for credentials not showing
  • November 1, 2017
  • 73 views
I have a working post install script thar installs two SMB printers. The prompt asking for credentials does not automatically appear. Instead i have to send output to the printer which are then paused waiting for authentication. A refresh/retry of the print queue forces the prompt to appear so the student can entrr there Active Directory credentials. Apart from this the script works well.
Is there a specific command that can be added which brings the promt window up without the refresh of the print queue?
Best answer by iJake
In your lpadmin command add this at the end:
-o auth-info-required=username,password
1 reply
iJake
Forum|alt.badge.img+23
  • November 1, 2017
