Mac Mini M1 with Big Sur 11.2.1 Remote Management is being managed
  • February 18, 2021
  • 4 replies
  • 93 views
Hello Everyone,
Im testing out a mac mini M1 with big sur 11.2.1 for the first time and i noticed something new happening which i never saw before with my Intel mac mini's (Running both Catalina and Big Sur).
As soon as i enroll the mac mini, manually, into my Jamf Pro instance im getting disconnected from ARD, only SSH works, and the Preference Pane for Remote Management now show's a new message that "Screen Sharing is managed", and i cant connect anymore to Remote Management.
Has anyone tackled this issue before?
I did open a case with Jamf but im trying to see if anyone has seen this happen before and maybe can give me a solution.
Im attaching screenshots.
Thanks in advance.
Best answer by MikeyD
It's not a problem till I install the workstation/laptop JAMF Profile Management Profile.  Then all goes to hell.
I did find an article which is a work around, but for me...it's been a hit or miss fix.
  • August 10, 2021
Hi - did you ever get this problem solved?
  • November 22, 2021
I have the same issue no idea whats causing it
  • December 13, 2021
  • July 9, 2022
Hi Mikey,
Could you share me that article?
