Machines not checking in
  • Oct 28, 2021 9:05 AM UTC
  • 30 replies
  • 416 views
Show first post
walkeri3rd
  • Jun 29, 2022 1:50 PM UTC
I am experiencing the same. Has anyone found a resolution.
Xxxxxxxxxxxxxxxx ~ % sudo jamf recon -verbose
 verbose: Timeout: 10
 verbose: Checking availability of xxxxxxx/…
 verbose: JMFCommons.JamfKeychain.JamfKeychainSecurityError.failedToReadJmfKeychainPassword
 verbose: Error Domain=com.jamf.jamfsecurity.error Code=-25293 "unlockWithPassword:error: : The user name or passphrase you entered is not correct." UserInfo={NSLocalizedDescription=unlockWithPassword:error: : The user name or passphrase you entered is not correct.}
There was an error.
     Device Signature Error - A valid device signature is required to perform the action.
whiteb
  • Sep 14, 2022 6:46 PM UTC
There was an error.
I'm seeing this as well on machines.
sudo jamf enroll -prompt
and re-enrolling seems to fix.
  • Sep 23, 2022 9:22 PM UTC
I had a stubborn MacBook Pro that wouldn't finish inventory. The "sudo jamf enroll -prompt" worked for me. Thanks!
  • Sep 25, 2023 3:43 PM UTC
Old thread I know, but recently had a bunch of machines failing to check in. What I found is that majority of these machines were running "jamf policy" and getting stuck, some of them went back months even.
I ran a "sudo killall jamf" on them, followed by "jamf policy" and they started checking in again without the need to re-enroll the device(s).
I do have a 3rd party patching tool though that allows me to push out scripts and stuff to machines, so that helped bypass Jamf where it couldn't talk to machines.
Its not ideal but better then walking around to 34-40 machines. I think Jamf should deploy some sort of failsafe where if a policy runs for so many hours or days it kills itself and restarts. I think that would fix a lot of these issues where machines are falling off and failing to check in.
Hope this help others.
Ke_ReM
  • Oct 16, 2023 3:48 PM UTC
Didn't fix the issue for me, still hangs on "Locating hardware information".
Macos 12.6.9
Jamf 10.50.0
