macOS 12.5 wifi connect problem
  • Sep 22, 2022 10:50 AM UTC
  • 82 views
Please let me know if you have problem with wifi connection to corporate network after upgrade macOS to version 12.5. Now in our environment every Macbook prompt users for credentials before connect to wifi instead of using installed certificate. In version 12.4 everything worked fine. I would be grateful for the tips. Thanks!
coachdnadel
  • Sep 22, 2022 4:41 PM UTC
Assuming your devices are still bound, unbind and rebind should do the trick. I have to do that process with 3 or 4 devices a day in my environment.
donmontalvo
Forum|alt.badge.img+36
  • Sep 22, 2022 5:21 PM UTC
Did you test on 12.6?
  • Sep 23, 2022 11:04 AM UTC
Of course... I should have done this firstly :) Upgrade to 12.6 resolved the problem. Thanks a lot!
