macOS Platform SSO for Microsoft Entra ID with Jamf Pro
  • November 27, 2025
  • 129 views
Mowmow003
I just want to ask, before we deploy PSSO for better MFA authentication, does Device Compliance need to be enabled in Jamf and does the device need to be registered in Entra? Is that correct? Because I thought we could deploy the company portal and then the configuration profile based on the Jamf documentation.
yugandhar
  • November 27, 2025
Hello
If you want to check the device compliance status, then it must be enabled. For PSSO deploying, the company portal and configuring the profile are enough.
yugandhar
  • November 27, 2025
You can followthe above link for your reference
