macOS Randomly Prompting for recovery key
  • Jun 7, 2021 5:54 PM UTC
  • 36 replies
  • 598 views
Show first post
  • Dec 17, 2021 11:04 PM UTC
That's sad to hear @bfreezy  I was thinking this was cleared up on Monterey. I had thought with some of the later Big Sur revisions it got better.
Agreed. I've flipped our Software Update profile to stop downloading updates in the background. Will likely open up a case with Apple if things don't improve.
  • Jan 10, 2022 1:43 AM UTC
This just happened to my wife’s work issued computer. It restarted on its own. Now it’s asking for a recovery key that she NEVER generated, and to her knowledge, no one generated for her. Suffice to say, she has no recovery key. What is the solution?
  • Jan 10, 2022 6:38 AM UTC
Almost certainly if it’s a work computer it will be encrypted, and she will need to contact her IT dept for it.
The key is automatically generated and escrowed with the jamf server. The
jamf admin can retrieve it and sent it to her.
  • Mar 28, 2023 3:11 PM UTC
Well I found this thread due to the Ventura 13.3 update. I'm sorry, I know the thread is old. I had to deal with this issue this morning. I'll search for a newer thread.
can confirm its still happening even on 13.3
We are setting this happen as well with the 13.3.1 update first time we have ever seen it. Only seems to be on the M2 Macs so far.
BL-ay
  • May 22, 2023 3:48 PM UTC
We also have this problem since version 13.3.
All Apple silicon devices are affected.
I will open a support ticket and keep you updated.
Hi @BL-ay
Thank you, was wondering did they reverted to your support!
Cheers!
  • Apr 3, 2025 5:03 PM UTC
Hi everyone,
Has anyone found a solution for the issue where users are randomly prompted to enter their recovery key? We’ve seen this happen a few times over the past couple of days, mostly on devices running macOS Sonoma. Any insights or fixes would be greatly appreciated.
HaiJinx
  • Apr 28, 2025 4:43 PM UTC
To anyone following this thread, we believe the issue was isolated to specific set of circumstances:
- Mac computer with Apple silicon
- Automated Device Enrollment with standard user created from the Setup Assistant
- Standard user is the only SecureToken-holder (aka "volume owner")
- FileVault is enabled
- Configuration profile with Software Update payload configured to automatically download available updates. (also possible to trigger with a softwareupdate -d -a command in place of profile to download the update.)
Once the update is downloaded, the next time the computer is restarted it will boot to the Recovery Assistant. Since the user isn't an administrator with a SecureToken, authentication by personal recovery key (PRK) is requested instead. This appears to affect computers with admin users too, but they are instead prompted to enter their password instead of a recovery key.
If this appears to be the issue you're encountering, please contact support and reference PI-009844 for us to track impact and escalate with Apple. If you are escalating with Apple directly to share impact, you can reference FB9196443 or AppleCare case #101417267535
Not yet resolved. We are on Sonoma and still getting random recovery key prompts after pushing software update via Jamf Software Update under Content Management. In this case all computers were Sonoma and all user profiles were admin.
