need help converting script to user bearer token
  • Mar 18, 2024 4:48 PM UTC
  • 0 replies
  • 26 views
need help converting script to user bearer token. script below:
## API information
apiURL="https://jamfcloud.com:8443"
apiUser=“test”
apiPass=“test”1234
## Get a list of all sites and their IDs
allSiteData=$(curl -H "Accept: text/xml" -sfku "${apiUser}:${apiPass}" $apiURL/JSSResource/sites | xmllint --format - | awk -F'>|<' '/<name>|<id>/{print $3}')
## Split out Site Names and Site IDs into arrays
allSiteNames=("$(echo "$allSiteData" | awk 'NR % 2 == 0' | grep -v 'Provisioning' | grep -v 'Ground Control')")
## Prompt for a Site selection
chosenSite=$(/usr/bin/osascript << EOF
activate
set siteNames to do shell script "printf '%s\\\\n' \\"${allSiteNames[@]}\\""
set namesForDisplay to paragraphs of siteNames
set chosenSite to choose from list namesForDisplay with prompt "Choose a Site"
end tell
EOF)
sleep 5
## Get the computer serial number
computerSerial=$(ioreg -rd1 -c IOPlatformExpertDevice | awk -F'"' '/IOPlatformSerialNumber/{print $4}')
## Update/change the Site for the computer
echo "<computer><general><site><name>$chosenSite</name></site></general></computer>" | curl -sfku $apiUser:$apiPass -d @- "$apiURL/JSSResource/computers/serialnumber/$computerSerial/subset/general" -X PUT -H "Content-Type: application/xml"
siteName=$(curl -H "Accept: text/xml" -sfku "${apiUser}:${apiPass}" $apiURL/JSSResource/computers/serialnumber/${computerSerial}/subset/general | xmllint --format - | grep '<name>Provisioning</name>')
if [[ $siteName == *"Provisioning"* ]]
then
sh /Library/test/Scripts/site.sh
/Library/Application\\ Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType fs -title "" -icon "/usr/local/CHOP_Logo.icns" -heading "Configuration Completed " -description "Shutting Down!""" &
sleep 10
echo completed > /tmp/completed.txt
