Need help with Finder "connect to" option
  • Sep 9, 2026 12:43 PM UTC
  • 5 replies
  • 82 views
LaurentCh
Hi there,
I’m experiencing an issue that has suddenly appeared on several Macs in my fleet, which is managed using an on-premises Jamf Pro server.
On an increasing number of Macs, the “Connect to Server…” option in the Finder’s “Go” menu has disappeared.
I am not applying any specific configuration profile that blocks certain features. I only customize the Dock by adding quick access to applications from the Microsoft Office suite, our VPN, and the Macintosh HD icon on the desktop.
A user can still browse the folders on their server through their Finder browsing history, but they can no longer access the “Connect to Server…” option.
Could you please help me understand what might be causing this issue?
Thank you.
Best answer by agungsujiwo
Ok i found, i push a Configuration Profile for Setup Manager, and this is where i customise the Finder.
Connect to and Go to were unchecked.
Thank You.
Great!
If you are testing a local profile and want it to take effect quickly, you may need to log out and log back in to the Mac.
If you have already pushed the profile but it hasn’t taken effect yet, you can try logging out and back in. This should trigger the profile to be applied.
agungsujiwo
  • Sep 10, 2026 2:23 AM UTC
Please double-check that you don’t have any restrictions configured under:
Configuration Profiles → Finder → Connect to Server
Could you check whether the Connect to Server option is disabled in any of your Configuration Profiles?
LaurentCh
  • Sep 10, 2026 6:31 AM UTC
​@agungsujiwo thank you for your answer, i’m going to take a look at the pushed configuration profiles
LaurentCh
  • Sep 10, 2026 7:22 AM UTC
Thank You.
agungsujiwo
  • Sep 10, 2026 7:27 AM UTC
Thank You.
Great!
LaurentCh
  • Sep 10, 2026 7:32 AM UTC
Ok thank you for the tips, usually i force restart the Finder if the Configuration Profile is too long to be apply.
