Negative Lab Pro
  • Sep 15, 2024 6:18 PM UTC
  • 82 views
Hi wondering if anyone has any tips on installing Adobe Plug-ins that are serialized so the plug in will work for all users.
AJPinto
  • Sep 16, 2024 11:06 AM UTC
Could you provide more detail as to what you are asking? How I am reading this is you are trying to deploy 1:1 licensed software to 1:many which is not something you should do, but I may be reading this wrong.
mvu
  • Sep 16, 2024 4:07 PM UTC
Might be worth reaching out to Negative Lab Pro on this plug-in licese. They may require additional licenses for a shared workstation.
For our use case, we activate the license per user. Curious what you find for a shared, all users, Mac.
https://www.negativelabpro.com/guide/installing/#activating-your-license
