No "Smart Device Group Membership Change" Emails Since SSO Conversion
  • Aug 28, 2026 1:32 PM UTC
  • 108 views
frank_arena
On Aug 18th, I changed over to the SSO integration in Jamf Pro Cloud. I have always had my SMTP server settings configured for email notifications on Smart Device Group Membership changes. I no longer receive those emails even though the box is still checked to do so. In the SMTP settings in Jamf Pro, I can send a test message and I DO receive that but just not any of the membership change emails that I want to. Is this a known issue or is there something I am missing? Any and all help will be appreciated.
Best answer by frank_arena
I found out that when my accounts converted over, all the options/checkboxes under notifications were reset. Checked what I needed and I’m good to go.
frank_arena
  • Sep 25, 2026 3:48 PM UTC
atomczynski11
Forum|alt.badge.img+19
Also look at configuring your dashboard view if you use it, and Search Preferences within Account Preferences (Contains vs Exact Match).
I believe those need to be setup as well.
frank_arena
  • Sep 28, 2026 2:00 PM UTC
Everything else stayed so that is why I was confused with the conversion and that notification setting.
