Patch Reporting: Java 8
Forum|alt.badge.img+19
I have noticed that my JSS (9.93) Patch Reporting isnt up to date with the current version of Oracle Java 8.
The current version is 1.8.121.13
JAMF (incorrectly) maintains that the current version is : 1.8.112 (which is at least 1 or 2 version behind)
I have waitied a few days, but the JSS hasnt updated yet.
Is there a way to force the update process?
  • 1143 replies
  • January 20, 2017
@dstranathan - should update today. It's one version behind.
see this thread
  • 7882 replies
  • January 20, 2017
Might want to read thru this thread, especially the last few posts - https://www.jamf.com/jamf-nation/discussions/21615/force-update-of-patch-reporting-titles
It seems Jamf needs to find some way to speed up the process a little bit more. Its understandable there will always be some delay since Jamf needs to actually take a look at the update and test it before they push out an update to their patch management reporting functions. But things like Java and Flash are critical to getting out as soon as possible, since its a safe bet that any update on those products is patching vulnerabilities. We're no longer in the "its just some new features" stages with those 2 products. The patches are to plug up holes that could be exploited.
  • 41 replies
  • January 26, 2017
Has anyone seen any changes in their JSS concerning patch reporting? Mine still shows the incorrect versions of patches for both Java and Flash player.
  • 1143 replies
  • January 26, 2017
@gregleeper ours is current as far as I can tell
  • 41 replies
  • January 26, 2017
@CasperSally , thanks. I'll try to see what's happening with mine.
  • 568 replies
  • January 26, 2017
My JSS is currently up to date.
Cookie policy
Cookie settings
